Thread: 121% Injector duty cycle with stock car
Results 1 to 6 of 6
  1. #1 121% Injector duty cycle with stock car
    Feb 2008
    I did a few scans of a friend's NA GP tonight and noticed that at full throttle that his IDC's are above 100%. What could be causing this? I haven't changed the flow rates at all, so I hope the rates aren't off. Are there better values for the flow rate table that I should use for his car?
    The only thing that has been modified on the car is a CAI and a 2.5" catless DP.
  2. #2 Re: 121% Injector duty cycle with stock car
    GT Level Member TurboKent's Avatar
    Woodward, OK
    still having troubles i see, i'm not sure about this one.
    2003 Grand Prix turbo intercooled
  3. #3 Re: 121% Injector duty cycle with stock car
    Feb 2008
    Quote Originally Posted by TurboKent View Post
    Yea we are. I got rid of the light throttle KR by disabling the EGR, but now, this... lol
    I hope it's not the pump on such a new car (it's an '05 BTW). The filter probably hasn't been changed since it was new, so I'll suggest that to him. Any other ideas??
  4. #4 Re: 121% Injector duty cycle with stock car
    GTP Level Member Scimmia's Avatar
    QCA, IA
    clogged filter or weak pump maybe?
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: 121% Injector duty cycle with stock car
    Hoffman/Schaumburg, IL
    Check Fuel pressure! sounds like you have a pressure issue
  6. #6 Re: 121% Injector duty cycle with stock car
    Feb 2008
    Okay. Once again, I'll have to wait until I get a chance to work on his car, but I'll check it out when I can.
  1. Heavy duty scratchs
    By DesQ27 in forum Visual/Body Modifications
    Last Post: 11-06-2008, 10:32 PM
  2. 99% Injector duty
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 11:13 PM
  3. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
  4. Injectors, what is the max duty cycle?
    By Stonewall in forum PCM Tuning
    Last Post: 03-16-2008, 09:49 AM
