Thread: Hunting Idle
Results 1 to 3 of 3
  1. #1 Hunting Idle
    Oct 2012
    Detroit Area
    So I have a 2004 w/ the 3.8L NA... and I am having an issue with my idle. It has yet to stall out on me, but when i'm in drive or sometimes even in park I find the car hunting trying to find a stable RPM to run smoothly. This most commonly occurs when the A/C is on as well. It hunts between 400-1000rpm and shakes a little bit. When I hold the throttle a tiny bit, it cures this issue. Any ideas?
  2. #2 Re: Hunting Idle
    Gunked up throttle body most likely if you haven't cleaned it.
    Try that, it's free.
    Clean the MAF sensor too...get some MAF cleaner at your local parts store.
    If you've never done LIM gaskets...that might be your next step...as the '04 cars didn't have metal LIM gaskets from the factory.
  3. #3 Re: Hunting Idle
    Oct 2012
    Detroit Area
    I've cleaned the throttle body, replaced plugs, wires, and coil packs to try and fix this already... haven't cleaned the MAF yet but that might be a good next step... and just out of curiosity.. how would the LIM gasket effect idle speed?
    Thanks!
    oh also for more info here, i have about 120k on the car, 180deg stat and a zzp tuned pcm.
  1. New here. 99 GT hunting idle issues
    By slvr99 in forum General Tech Discussion
    Last Post: 05-30-2011, 10:58 AM
  2. 99 GT hunting idle issues
    By slvr99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2011, 11:09 PM
  3. Hunting at an idle
    By buthead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 03:12 AM
  4. Hunting
    By TCO in forum Off Topic Discussion
    Last Post: 10-08-2008, 09:21 PM
  5. Rough/hunting idle
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 11:22 PM
