Thread: New here. 99 GT hunting idle issues
Results 1 to 8 of 8
slvr99 New here. 99 GT hunting idle... 05-28-2011, 06:41 PM
cerick08GP Re: New here. 99 GT hunting... 05-28-2011, 07:45 PM
slvr99 Re: New here. 99 GT hunting... 05-28-2011, 07:49 PM
slvr99 Re: New here. 99 GT hunting... 05-28-2011, 08:36 PM
cerick08GP Re: New here. 99 GT hunting... 05-28-2011, 09:32 PM
matt5112 Re: New here. 99 GT hunting... 05-28-2011, 11:18 PM
Scottydoggs Re: New here. 99 GT hunting... 05-28-2011, 11:25 PM
slvr99 Re: New here. 99 GT hunting... 05-30-2011, 10:58 AM
  1. #1 New here. 99 GT hunting idle issues
    May 2011
    Washington
    First post, bare with me. Have a 1999 gt 3.8 and just changed the fuel pump and alternator after they both failed in hospital parking lot (another story for another day), now I have a code for the MAF 0102 and when I rev the engine it hunts for an idle speed, the tach bounces between 600 and 1200 rpm before finally idling at 800. Also it seems a little hard to start, have to turn it over several times before it will fire and run. The car runs great, better than it has in along time. Any suggestions welcome, Thanks.
  2. #2 Re: New here. 99 GT hunting idle issues
    GTX Level Member cerick08GP's Avatar
    I have a couple suggestions for you. First stay out of hospital parking lots. Secondly your MAF sensor is probably broken. If you disconnect it, and it idles better that would indicate the MAF is bad. You might want to try cleaning it first, it could be dirty.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: New here. 99 GT hunting idle issues
    May 2011
    Washington
    Cleaned MAF sensor, no change. Will try disconnecting it. Thanks.
  4. #4 Re: New here. 99 GT hunting idle issues
    May 2011
    Washington
    Disconnected the MAF, no change to idle. ???
  5. #5 Re: New here. 99 GT hunting idle issues
    vacuum leak, maybe...
    2008GP
    2002GP||sold
  6. #6 Re: New here. 99 GT hunting idle issues
    I moved your thread for you.
    Please try and post in the appropriate section next time.
    Thanks.
  7. #7 Re: New here. 99 GT hunting idle issues
    check the wires leading to the plug for the maf, they tend to dry up, look for cracks in the insulation on the wires, i had to install a new pig tail for my maf last year.
  8. #8 Re: New here. 99 GT hunting idle issues
    May 2011
    Washington
    After looking for vacuum leaks and cleaning the IAC and replacing the MAF sensor (140.00) it turned out to be a 10 cent fuse. It was fuse #21 IGN1UH.
    Thank you all for your suggestions.
  1. idle issues
    By gnjim in forum General Tech Discussion
    Last Post: 03-06-2012, 01:46 PM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. Hunting at an idle
    By buthead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 03:12 AM
  4. Idle issues! HELP!
    By mostfunwithfire in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-24-2009, 06:30 PM
  5. Rough/hunting idle
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 11:22 PM
