Thread: Oil Leak, Which gasket?
Results 1 to 10 of 10
  1. #1 Oil Leak, Which gasket?
    SE Level Member HOPPY's Avatar
    Jul 2008
    Howell, MI
    So i have been losing about a half qaurt of oil every two weeks and on cold starts the car struggles to start then when it does it revs up to about 2000rpm, also on cold starts a ton of smoke comes from the exhaust and it smells like burning oil. So looking at the engine and i can see that it is very wet under the intake manifold and behind the front header, looking at the left side of the engine. I've heard of some gasket failing often in the 3800 but which is it? Any info about the gasket or what other problem there is with my car would be greatly appreciated!!!
    Thx, Hoppy
  2. #2 Re: Oil Leak, Which gasket?
    Oklahoma
    Lower Intake Manifold gasket. The originals were plastic and didnt hold up well. The newer ones are Aluminum and pretty much solve the issue.
  3. #3 Re: Oil Leak, Which gasket?
    Jul 2008
    Howell, MI
    awesome thanks alot, should I have the dealership do this or just a shop??
  4. #4 Re: Oil Leak, Which gasket?
    Oklahoma
    Well, if you are comfortable working on your car, you can do it for the cost of LIM gasket, and maybe some fuel Orings, thread sealant and probably a couple other cheap things I cant recall and a few hours work.
  5. #5 Re: Oil Leak, Which gasket?
    Jul 2008
    Howell, MI
    Yea I acctually might do that after seeing that people payed over 1 grand to get it fixed, I've watch the tutorial N i should be able to handle it if my dad lets me but well see... I can't beleive GM hasn't had a recall with this yet
    If I end up doing the replacement myself I'll try to take some pics or a video to make another how to, but for the GT
  6. #6 Re: Oil Leak, Which gasket?
    Bastard Reptile's Avatar
    Kansas City, MO
    Blue smoke on startup usually points to bad valve seals. Intake gaskets are also probably shot, along with the valve cover gaskets.
  7. #7 Re: Oil Leak, Which gasket?
    Louisville, KY
    Hurry up and do the video, I need to replace my gaskets now too.
    My Cardomain
  8. #8 Re: Oil Leak, Which gasket?
    Jul 2008
    Howell, MI
    heres the video I watched, These guys make it look easy and I have a feeling It's not gonna go as smooth for me.... Would one of those gasket sealers and piston ring lubricants that you poor in the oil work as a quick fix or just a waste of money??
    http://www.cpaclubgp.com/misc/lim-gasket.html
    Edit: Forgot the video link
  9. #9 Re: Oil Leak, Which gasket?
    Jul 2008
    Poteau Oklahoma
    ahh common you can do it.
    and for the record any additives that you use, if they do work its not going to fix the problem, just mask it untill it is absoluity a do or die issue. do your self a favor and fix it. asap.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  10. #10 Re: Oil Leak, Which gasket?
    Jul 2008
    Poteau Oklahoma
    oh I love that part at 16:00.
    thats just toooooooo goooooood.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  1. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  2. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
  3. head gasket?
    By Mikefisher in forum General Tech Discussion
    Last Post: 10-10-2008, 12:36 PM
  4. VC gasket issue?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 06:50 PM
  5. Oil Pan Gasket Replacement
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2008, 01:18 PM
