Thread: VC gasket issue?
Results 1 to 6 of 6
  1. #1 VC gasket issue?
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    so i have a 2001 gtp with 114k on it and i noticed today that there was a slight amount of smoke comming off the front header. when i investigated a bit more, the head just above the header looks oily. so i am thinking that my valve cover gasket is shot...is that what i am looking at? and if so how hard is it to replace them?
  2. #2 Re: VC gasket issue?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    That appears to be the most likely culprit. I would make sure the oil cap and filler tube [not sure the technical name] are tight and also you may wann try snugging up your bolts around the valve cover. Be careful not to go too tight, breaking one of those in your block would cause a bigger problem. After checking the above clean up the area [i use break cleaner and then compressed air]. Then test drive the vehicle and see if your problem goes away. If not then it could be the gasket, or the valve cover could be cracked.
    I'm not sure how frequent the latter would occur but it is plastic so i would think it is a possibility.
    2006 Grand Prix GXP
  3. #3 Re: VC gasket issue?
    Aug 2008
    denver, co
    i will clean it tonight asnd drive it till sat. how often do the gaskets fail on the 3800's? and is it better to get the rubber of cork replacement?
  4. #4 Re: VC gasket issue?
    Jul 2008
    New York
    Its been my experience that rubber gaskets are more durable. I have mostly worked on transmissions and the cork breaks apart more and sticks to things more making future replacement harder. Also if you over-tighten something with a cork gasket it could break easier especially if their is oil on it.
    2006 Grand Prix GXP
  5. #5 Re: VC gasket issue?
    Aug 2008
    denver, co
    right on! well thanks for the help! and hopefully i will not have to post in this thread again! *knock on wood*
  6. #6 Re: VC gasket issue?
    Jul 2008
    New York
    Your welcome. Further here's a thread detailing how to go about your project. http://www.grandprixforums.net/f17/v...kets-5464.html
    2006 Grand Prix GXP
  1. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  2. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  3. Did I get good advice? Really LIM gasket Issue?
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-02-2008, 12:16 PM
  4. Oil Pan Gasket Replacement
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2008, 01:18 PM
  5. Upper Gasket
    By TyroElite in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2007, 03:54 PM
