Thread: Engine running hot 04
Results 1 to 20 of 25
  1. #1 Engine running hot 04
    Apr 2013
    Michigan
    i have a 04 Grand Prix gt2 and ever since i got the car it had been running hot (like one bar after 3/4) idk why? i recently did a radiator flush and that didnt help anything. If anyone has had this issue before and know what the problem is please help..
  2. #2 Re: Engine running hot. plzzzz help
    gardner,mass
    have you change the therm?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    i have not but i tested the one thats currently in there and it opens and closes just fine
  4. #4 Re: Engine running hot. plzzzz help
    gardner,mass
    ya but did you test at what temp? And what did you put for coolant in there and what did it have befor. Did you bleed the air out? Maby change the coolant temp sensor. cooling system is pretty cheap you could replace the entire thing for under 100 bucks. (coolant temp sensor, thermostat, water pump, rad cap)
  5. #5 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    it opened up at 195 i think. and where is the coolant temp sensor located ?? i was thinking about replacing the water pump but didnt want to if that wasnt the problem
  6. #6 Re: Engine running hot. plzzzz help
    Cambridge, Ontario Canada
    Have a quick look under your oil fill cap & in the valve cover. See any white stuff? Coolant temp sensor is located in the Lower intake manifold just under where the T stat goes.
    2005 E55 - stock
  7. #7 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    There is no white stuff when i look when i looked under the oil fill cap.
  8. #8 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    is there any way you can test the sensor or is it better to just replace it ?? its only a few dollars
  9. #9 Re: Engine running hot. plzzzz help
    Should test it, replacing is a bigger job that involves draining coolant from the LIM
    2005 E55 - stock
  10. #10 Re: Engine running hot. plzzzz help
    your fans working? should come on around 212.
    and also turn on when the a/c is turned on. if the a/c dont work, the fans wont come on via a/c command, but should still work for cooling as normal.
    when i bleed my engine for air, i like to let it idle till the fans come on, that way you know the t stat is opened up.
  11. #11 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    A/c does work. i have bleed my car but i have never bleed it when the fans were on... Do you think that could be the problem i mean it wont hurt to try...
  12. #12 Re: Engine running hot. plzzzz help
    bleeding the air cold dont always work, the bleeder is on top if the t stat, so if its closed, nothing is pushing the air out.
  13. #13 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    what else could it be? im going change the tstat and the coolant temp. sensor this weekend and make sure there is no air in the system but i dont have much faith that its going fix my problem
  14. #14 Re: Engine running hot. plzzzz help
    we've seen bad water pumps make a car run hot. most of the time its air trapped and needs to bled out.
    or your engine is running perfectly and your temp gauge is off.
    these cars will run over the 1/2 point, they like to be 200 degs or more. its where the temp lives on most 3800 engines.
    lots of new owners think their car is running hot when its not at all. as long as it dont ever hit the red, then theres a over heating problem for sure.
  15. #15 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    Alright so today i pulling out of my driveway and seen a puddle of coolant.. i let the car warm up and was looking under the hood for leakes and i found it, it was the heater hose elbow. but that was the first time i have even seen coolant on the ground and before that the car use to run hot.. im going relpace the elbow this weekend as long as with the tstat and new coolant. should i consider replacing the water pump while im at it ???
  16. #16 Re: Engine running hot. plzzzz help
    with the belts on still ( engine off) grab the w/p pulley with 2 hands, one on each side, push one side, pull the other, then the other way, if it moves, change it, if not, id let it go for now. they cost around 40 bucks, so if its in the budget it can be done. i just hate changing parts that dont need to be changed.
  17. #17 Re: Engine running hot. plzzzz help
    Apr 2013
    Michigan
    Is there anything else I should replace while I have the coolant out ?? I also couldn't find the radiator drain plug..
  18. #18 Re: Engine running hot 04
    dont waste your time with the drain plug, pull the lower rad hose, off the engine or the rad.
    also your lower and upper intake gaskets should be replaced on general principals, being they are plastic and already leaking some as we speak.
  19. #19 Re: Engine running hot 04
    Apr 2013
    Michigan
    I just replaced my two heater hose elbows and the Tstat what's the proper way to bleed the system so there isn't any air?
  20. #20 Re: Engine running hot 04
    Mar 2013
    Cleveland
  1. engine running warm?
    By wiwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2011, 11:00 AM
  2. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
  3. Engine running hot
    By 04GTPCOMPG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 08:26 PM
  4. engine running for poo
    By patchedboard in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-09-2009, 04:50 AM
  5. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
