ya but did you test at what temp? And what did you put for coolant in there and what did it have befor. Did you bleed the air out? Maby change the coolant temp sensor. cooling system is pretty cheap you could replace the entire thing for under 100 bucks. (coolant temp sensor, thermostat, water pump, rad cap)
