Thread: Fuel line leak at fuel rail
Results 1 to 8 of 8
  1. #1 Fuel line leak at fuel rail
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Hi guys, the fuel line where it attaches to the fuel rail is leaking, dripping down on the intake. Is that just an O-ring in there or is the connector shot? That's one of GM's infamous quick-click or they call it. Must have pushed/pulled a little toooo much when wrestling that a/c accumulator line in last weekend....
  2. #2 Re: Fuel line leak at fuel rail
    Yeah just replace the orings, take one out and go to Oreillys or Autozone and pick up the help ones that are the same size. They are not the easiest thing to remove or re install just giving you heads up.
  3. #3 Re: Fuel line leak at fuel rail
    Dec 2008
    ****'s Creek
    Ok thanks
  4. #4 Re: Fuel line leak at fuel rail
    Dec 2008
    ****'s Creek
    Quote Originally Posted by slick2500 View Post
    You ain't #$^& %@! kidding.....any tool or tips on this? They came out pretty easy with a small hooked pick tool, but trying to one back in there is a nightmare. Apparently the connector is part of the fuel line, not sold separately so I have no choice but to get these O rings back in there.....
  5. #5 Re: Fuel line leak at fuel rail
    i also had this fight, i had 2 size O rings, a smaller one, and a larger one, and a plastic ring inside as well. i took that ring out, to get the smaller O ring in, then the ring went back in, then the larger O ring. iirc that is, its been i while since ive been inside there.
    i took the return line off for reference, just to peek inside it.
  6. #6 Re: Fuel line leak at fuel rail
    I used a small jewelers philips screwdriver to put mine back in.
    Sent from my mobile office.
  7. #7 Re: Fuel line leak at fuel rail
    Feb 2013
    37.295091, -121.930053
    fight the leak
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: Fuel line leak at fuel rail
    Dec 2008
    ****'s Creek
    I was able to locate this thread that had some good info. It seems that plastic retainer at the end pops out and then you can stack everything back together. I used an offset screwdriver to pop it out. So instead of having to wiggle the o-rings in there and get them positioned, you can just insert the first o-ring, then the spacer, the next o-ring, then snap the retainer back in.
  1. fuel line leak on top of s/c
    By Scottydoggs in forum General Tech Discussion
    Last Post: 01-27-2012, 03:50 PM
  2. Fuel rail/line o rings? (top S/C)
    By txslow6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2011, 10:23 AM
  3. fuel line leak
    By anlo in forum General Tech Discussion
    Last Post: 12-19-2010, 09:39 PM
