Thread: Replace the motor or not
Results 1 to 7 of 7
  1. #1 Replace the motor or not
    SE Level Member rc10gt7090's Avatar
    Jun 2011
    minneapolis
    So I was driving home yesterday and I noticed that I have a very noise lifter my car has 234,000
    So I was looking around and I can get a motor with 160,000 for $459. Or should I just replace the one lifter that’s bad? $216 for the seals lifters are $14 each
    on the fence on what I should do.
  2. #2 Re: Replace the motor or not
    You could try running a engine cleaner first to try and get the noise to stop.
  3. #3 Re: Replace the motor or not
    Or you could just get ls7 lifters they run around $115 or so for a set and replace yourself. I wouldn't go swapping the motor just because of a lifter tick.
    04 Comp G.
  4. #4 Re: Replace the motor or not
    Jun 2011
    minneapolis
    so i pulled the top end off my motor and all the lifters on the back side of the motor are bad. so looks like I will be geeting some new lifters.
  5. #5 Re: Replace the motor or not
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Easy enough to do, make sure to get new pushrods while you are there they are cheap and probably worn funny if not destroyed from bad lifters. then make sure to clean the lifter valley out when you put it back together.
  6. #6 Re: Replace the motor or not
    Jun 2011
    minneapolis
    so I got all the new liftres installed yaha for me but now that the motor has regained compreshion the lower end or pisston is nocking. I think I should have just replaced the motor
    gaskets 150
    lifters 120
    supplys 30
    ____________
    total 300
  7. #7 Re: Replace the motor or not
    May 2012
    Albuquerque, NM
    You just reminded me I should replace these when I top swap. Thanks
  1. How-To: Replace the Blower Motor on a 2000 Grand Prix
    By WalterWhite in forum How To Write-Ups/Tech Tips
    Last Post: 09-04-2015, 12:00 AM
  2. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  3. Just replace window regulator with motor and...
    By ajc549FF in forum General Tech Discussion
    Last Post: 03-16-2011, 06:30 AM
  4. how to replace a motor mount
    By taman86 in forum Brakes/Suspension/Chassis
    Last Post: 11-06-2010, 04:44 AM
  5. What tools and parts are needed to replace the LIM gasket on the S/C 3800 motor?
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2009, 09:46 AM
