Thread: swapping
Results 1 to 5 of 5
  1. #1 swapping
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    I have a 3.8 v6 natural. Engine blown and swapping with one with less mileage. What is needed besides the motor to do the swap. Everything comes with the motor.
  2. #2 Re: swapping
    Nothing really.
    Take out old motor, drop in new motor. Reuse the same pcm and wire harness.
  3. #3 Re: swapping
    St. Louis
    Updated aluminum LIM gaskets, updated UIM, coolant elbows, oil for 2 changes, gasket sealer, injector o-rings, blue locktite for the rear cover of the motor (do it now while it's out, trust me), coolant (either stock Dex, or conventional green as long as you flush the system), valve cover gaskets and bolt grommets all come to mind.
    Might as well do what you can while it's out of the car and have easy to access all of it ya know?
  4. #4 Re: swapping
    You aren't telling us what year you have or what the new motor comes from. We can't give you good information w/o some information upfront.
    For example, some of your H body cars will have a 258mm flex plate. And on that same note, some $t60 equipped H body's with SC motors had 245mm flex plates. Brackets etc.. there are slight differences. Only slight though, if you put the motors side by side, you could easily swap over any parts that were different w/o needed us to show you those differences.
  5. #5 Re: swapping
    May 2013
    Biglerville
    Thanks for the help guys
  1. K n N swapping for Amsoil
    By JT2002GTP in forum General Grand Prix Discussion
    Last Post: 03-28-2013, 04:33 PM
  2. 98 GTP swapping non S/C 3.8
    By brktracer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2013, 09:07 AM
  3. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  4. swapping an ls4 into a 97-03 gp
    By NineD9GT in forum General Tech Discussion
    Last Post: 06-29-2010, 08:26 PM
  5. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
