Thread: No spark 2000 impala
Results 1 to 13 of 13
  1. #1 No spark 2000 impala
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Helping my cuzin out again the now has no spark what could the problem be their is a code but its map. also put my msd coil packs in and didn't work.
  2. #2 Re: No spark 2000 impala
    Feb 2013
    37.295091, -121.930053
    try good coil packs like OEM ones. also see if your getting volts to the packs.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: No spark 2000 impala
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    swap out ICM?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  4. #4 Re: No spark 2000 impala
    Madrid Iowa
    She just went threw a devorce and cant afford much right now so she said she would talk to our gm mechanic. Thanks guys!
  5. #5 Re: No spark 2000 impala
    Mar 2012
    Dallas
    check ignition fuses and try swapping out the ignition control module ICM.
    she cant afford much, but she is going to a gm mechanic?
  6. #6 Re: No spark 2000 impala
    Madrid Iowa
    he is our friend, he looks at all of my familys cars for free...
  7. #7 Re: No spark 2000 impala
    Mar 2012
    Dallas
    good luck then. glad we could help...
  8. #8 Re: No spark 2000 impala
    Madrid Iowa
    Thanks for the help, sorry i couldent use it ): Oh well ill need help with the grand prix soon anyway lol
  9. #9 Re: No spark 2000 impala
    Did you pull a plug to confirm there is no spark?
  10. #10 Re: No spark 2000 impala
    Madrid Iowa
    Yeah, thats why i went home and got my MSDs and it still dident work, it should be getting fuel though because I could hear the pump turn on when I turned the key on.
  11. #11 Re: No spark 2000 impala
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Hard to pinpoint an issue like that. I don't know if a MAP sensor would cause no spark or not. If it's all the cyl not getting fire then yes, ICM would be my first guess, could also be a crank or cam pos sensor. I had a crank pos sensor go out and I had no spark (on a 3100). Could be as simple as a ground also. Let us know what it turned out to be.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  12. #12 Re: No spark 2000 impala
    Madrid Iowa
    I will let ya know. I was thinking Crank pos sensor but wouldent it have a code?
  13. #13 Re: No spark 2000 impala
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Map sensor will not cause a no spark scenario.
    Crank sensor can be bad without setting a DTC.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. 2000 Impala Like a Boss!
    By GrandPrixgtp2000 in forum Chevrolet Impala
    Last Post: 03-12-2013, 08:09 AM
  2. my gtp w/20s vs a early 2000's impala and spyder
    By GTPSHAWTY in forum Track Sessions and Kills
    Last Post: 07-28-2011, 11:38 AM
  3. 2000 GP GT no spark!
    By ToXiC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2010, 08:13 PM
