Thread: Engine Idles Fine, Kills when I Hit the Gas
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Engine Idles Fine, Kills when I Hit the Gas
    Quote Originally Posted by Liquid86 View Post
    Update:
    Went to town with a hammer on the Cat this morning, nothing. Tried unplugging the maf again, same problem, only this time it wouldn't even idle, it fired and killed right away like yesterday. I turned everything completely off, removed the key, tried again, same issue. Now however it kills while in idle if I touch the gas, MAF or Not, and when I can get it to idle, it definitely sounds like it's idleing a bit high. Got it to move enough to back it out of the garage a bit to put a jack under it. Still need to try to swap for my wife's MAF tonight when she gets home to see if that makes a difference, and thinking I should just bite the bullet and throw a new fuel filter on too.
    by chance did you hear stuff rattling around inside the cat? if so its also dead/ fell apart.
    and you'll need to drive it a bit hard for it to glow. idling wont do it.
  2. #22 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    No rattling or noise of any kind from the cat, and unfortunately I can't actually drive it, now it's just killing right after it fires, even at idle. I'm almost certain it's the MAF at this point.
  3. #23 Re: Engine Idles Fine, Kills when I Hit the Gas
    i'd just drop your wifes maf in your car, and see how it runs if at all. you would think a code would be there for a maf, or at least the check engine light come on.
    have you tried starting fluid yet? if it fires up, its fuel related then.
    and checked for fuel at the rail?
  4. #24 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Unbeknownst to me, my father-in-law has an ODBII reader, so I was able to pull the codes. P0107. MAP sensor low circuit. Explains why pulling the MAF didn't affect the problem. Checked the connector with the multimeter, voltage from the car is a rock solid 5v, nothing coming back. Gonna replace it tomorrow and check it again.
  5. #25 Re: Engine Idles Fine, Kills when I Hit the Gas
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    Any more updates? I'm having the exact same problems.
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  6. #26 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Yes actually... 4 weeks, and two tow trucks later I've ended up replacing both the MAF and the MAP now. Been a nightmare. Also had to replace my battery terminals, but my guess is that was just a coincidence.
    Frustrating as hell since the engine itself runs like a top.
    How many miles/what year is your vehicle?
  7. #27 Re: Engine Idles Fine, Kills when I Hit the Gas
    Jul 2010
    Michigan
    I have a 1999 with 212k miles on it. I had this problem two years ago and replaced the MAP and the MAF and it was fixed. Now I've replaced the PCV valve and the assembly (was broken) and when I'd unplug my MAF, it wouldn't run. So i didn't think that was the problem. Now, I cleaned the throttle body, and tried again, and it runs pretty good without the MAF plugged in. So i'm not sure what to think. Because i'm pretty sure it runs ok with the MAF plugged in (after i clean the throttle body).
  8. #28 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Have you rechecked for a MAP code? I've now replaced my MAP sensor twice since this all started. Broke down a third time and after getting it towed a Third time I found it was throwing the same MAP code (P0107 I believe, low circuit). Scared me since I didn't figure I should be burning out a brand new sensor that quick. Well, apparently after talking to a local mechanic that I trust and digging a bit online, the low-end MAP sensors from O'Reilly (or NAPA, or Auto Zone, or any other retailer) have a nasty habit of dying prematurely.
    Dropped a new, better one in and all is well again. Hopefully for a while this time.
  9. #29 Re: Engine Idles Fine, Kills when I Hit the Gas
    Jul 2010
    Michigan
    I was getting a code, I can't remember what it was. It was something to do with the MAF though. I think I'll try that out, but since this happened I got rear ended and totaled it. So it'll be my summer fixer upper and I just bought a 2001 Grand Prix today.
  10. #30 Re: Engine Idles Fine, Kills when I Hit the Gas
    Jul 2010
    Michigan
    So I replaced the MAF again on the car. It ran perfect for about day or so. Now it's having the same issues. Any ideas? Could it be the harness to the MAF?
  11. #31 Re: Engine Idles Fine, Kills when I Hit the Gas
    check the wires to the plug end for damage or missing or cracked insulation. if you find and of that get a new pig tail. if the code is for low voltage the wires could be damaged.
  1. Service Engine Light on; But car runs fine
    By JessicaRebel in forum General Tech Discussion
    Last Post: 02-02-2013, 03:38 AM
  2. 06 grand prix reduced engine light on turns over idles funny gas does nothing
    By stumpee1 in forum General Grand Prix Discussion
    Last Post: 01-24-2013, 11:50 PM
  3. Engine won't start or idles rough at above 180 degrees after its been shut off.
    By deathjunior in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2012, 09:57 PM
  4. Loss of power, idles fine
    By ritzer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 05:50 AM
  5. 04 Grand Prix engine light on but car runs fine what could this be?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 12-02-2011, 12:07 AM
