Thread: Engine Idles Fine, Kills when I Hit the Gas
Results 1 to 20 of 31
  1. #1 Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Hey everyone, new to the forums. I own two grand prixs, an 04 which I drive and an 06 which my wife drives, Both with the L26.
    I'm having a heck of a time with the 04, been trying to troubleshoot it for about two weeks. On the way back from the store (the parts store actually with a new water pump for my wife, unrelated repair), my RPM's took a nose dive and I almost stalled out. I pulled off to the side of the road and coasted for a bit, then accelerated and had the same thing happen. Eventually the problem went away and I made it home, accelaerating normally. The next day I started the car and it idled fine but as soon as I took it out of park and touched the gas even slightly it killed, completely this time. Started fine two more times, killing each time I put it in gear and hit the accelerator. Telltale sign of a dead fuel pump, or so I thought.
    So far I've replaced the fuel pump and cleaned the throttle body. I thought fuel filter, but it revs normally while in park and the filter isn't all that old. Also, the car will creep forward or backward normally at idle but as soon as I even tickle the accelerator the RPMs drop to zero and it stalls out.
    Totally at a loss, could it be the MAF? Should I just go ahead and replace the fuel filter? Or am I totally looking in the wrong place? Thanks everyone!
  2. #2 Re: Engine Idles Fine, Kills when I Hit the Gas
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    I would say it very well could be your maf. That's a pretty common sign for a problem with them when you touch the throttle just falls on its face. Try unplugging it while running and see if that make a difference. if you can accelerate I'd say you found your problem
  3. #3 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Unplugged the MAF and started it up, engine just kills, no idling, after about 3 seconds. Tried a couple times with identical results. Not getting a code either. To be honest I thought the car could run without the MAF so is it strange that it's just killing with it unplugged? Also, would the MAF allow the engine to rev normally in park, but not drive or reverse? Confusing problem, thanks for the tip though!
  4. #4 Re: Engine Idles Fine, Kills when I Hit the Gas
    Jul 2012
    Kansas city
    Can you keep it running and try to rev it?
  5. #5 Re: Engine Idles Fine, Kills when I Hit the Gas
    Jul 2012
    Kansas city
    It should run with it unplugged.. So it will rev fine in park but not in drive? Does it bog real bad in park while revving? May have a plugged converter
  6. #6 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Seems to rev ok while in park, like it's supposed to, what's the easiest way to check for a plugged cad? Exhaust flow seems normal.
  7. #7 Re: Engine Idles Fine, Kills when I Hit the Gas
    May 2012
    alabama
    MAF my 2000 GRAND PRIX GTX did the exact sane thing I first cleaned it and then that didn't work just replaced it and fixed ever since but there are other things that can cause the maf to read bad.
  8. #8 Re: Engine Idles Fine, Kills when I Hit the Gas
    May 2012
    alabama
    Remove upstream o2 and use an exhaust pressure gauge but not ever one has one of those. Does it lack horsepower?
  9. #9 Re: Engine Idles Fine, Kills when I Hit the Gas
    May 2012
    alabama
    Use a back pressure tester to confirm test for a clogged catalytic converter. Remove an upstream oxygen sensor install a back pressure tester. Usually the specifications will require back pressure to be below 1.0 psi. at idle and no more than 4 or 5 psi.at snap throttle.
  10. #10 Re: Engine Idles Fine, Kills when I Hit the Gas
    sounds like a clogged cat from here too, how many miles you got on it?
  11. #11 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    A hair under 200k miles.
  12. #12 Re: Engine Idles Fine, Kills when I Hit the Gas
    if you can still drive it at all, drive it at night and see if the cat is glowing red, if so its clogged. being that you said it bogged with no power, but then cleared up makes me thing the cats internals are broken and are blocking the cat exit port. you hit a bump, it clears up.
    sometimes beating the the cat with a hammer will clear it up as well if you cant even drive it right now. after assaulting the cat, if it runs better, you know its the cat.
  13. #13 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Thanks, definitely going to check on both the cat and MAF tomorrow then. I've never seen it though where the car will rev fine in park, but not accelerate in drive or reverse. Would I still get exhaust flow (it's easy to see being in MN) with a clogged cat? Anyways, I'll let everyone know how it goes in the morning, thanks for all the advice!
  14. #14 Re: Engine Idles Fine, Kills when I Hit the Gas
    any chance the check engine light was flashing when trying to gas it when it would not go with any power? if so that could be the cat as well.
    its kinda normal for it to rev ok feeling in park. once under load they kinda sound like a vacuum with a full bag.
    at 200,000 ish its quite possible for a bad cat.
  15. #15 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    No check engine light... actually the check engine light I had for the evap sensor turned off once I installed the new fuel pump, so I got that going for me :P,
    The MAF on my wife's car is the same so I can just do an easy swap, so i'll check both again tomorrow. One thing I will say is that it seems to start with extra "vigor" i guess you could say now, like it's getting more gas at start up (foot off the pedal), though that could just be the new fuel pump and clean throttle body.
  16. #16 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Just thought of something else, when I pulled off the throttle body today, a small amount of gas leaked out of the intake manifold. I also noticed some in the snow when I first had the problem and ended up just pushing the car into the garage. I honestly don't know if that's normal or not. I would presume so, but it seemed like more than should be there.
  17. #17 Re: Engine Idles Fine, Kills when I Hit the Gas
    gas? sure you dont mean coolant?
    theres should be no gas any where near the TB, only air flows through it, and coolant.
  18. #18 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Could very well have been, I had gas on my hands, but it was also a yellow/green in color, i'm going to say it was probably coolant.
  19. #19 Re: Engine Idles Fine, Kills when I Hit the Gas
    Feb 2013
    Minneapolis, MN
    Update:
    Went to town with a hammer on the Cat this morning, nothing. Tried unplugging the maf again, same problem, only this time it wouldn't even idle, it fired and killed right away like yesterday. I turned everything completely off, removed the key, tried again, same issue. Now however it kills while in idle if I touch the gas, MAF or Not, and when I can get it to idle, it definitely sounds like it's idleing a bit high. Got it to move enough to back it out of the garage a bit to put a jack under it. Still need to try to swap for my wife's MAF tonight when she gets home to see if that makes a difference, and thinking I should just bite the bullet and throw a new fuel filter on too.
  20. #20 Re: Engine Idles Fine, Kills when I Hit the Gas
    Quote Originally Posted by Liquid86 View Post
    Update:
    by chance did you hear stuff rattling around inside the cat? if so its also dead/ fell apart.
    and you'll need to drive it a bit hard for it to glow. idling wont do it.
  1. Service Engine Light on; But car runs fine
    By JessicaRebel in forum General Tech Discussion
    Last Post: 02-02-2013, 03:38 AM
  2. 06 grand prix reduced engine light on turns over idles funny gas does nothing
    By stumpee1 in forum General Grand Prix Discussion
    Last Post: 01-24-2013, 11:50 PM
  3. Engine won't start or idles rough at above 180 degrees after its been shut off.
    By deathjunior in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2012, 09:57 PM
  4. Loss of power, idles fine
    By ritzer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 05:50 AM
  5. 04 Grand Prix engine light on but car runs fine what could this be?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 12-02-2011, 12:07 AM
