You can go ahead and try to u bend that hose, there's no reason for coolant going through the tensioner bracket except space.
However..you'll find the two hoses are different sizes.
i would not ghetto rigify it with a ubend in the hose...i would use freeze plugs and plug the outlets coming from engine the right way. i found issue, not elbows at all. and NOW i started getting the tell tale sign of boiling coolant blowing pressure to the reservoir...just like i did in my talon a couple years back...parts sitting in box in car, just no time to put them on.
You can't plug them. The coolant makes a circuit from the timing cover to the LIM. You'd need to put barbs in those two and run a hose.
