Thread: coolant issues after elbow/lim/uim replacment
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #1 Re: coolant issues after elbow/lim/uim replacment
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    yeah, your discount is not the typical 10%, now its a percentage of how much you spend...i was getting 1.2% for normal stuff like oil change, etc. it may be the chain here in cali that blows. kragen/advance auto gave me a heck of a deal before. but not anymore. so i go with autozone...
  2. #2 Re: coolant issues after elbow/lim/uim replacment
    You can go ahead and try to u bend that hose, there's no reason for coolant going through the tensioner bracket except space.
    However..you'll find the two hoses are different sizes.
  3. #3 Re: coolant issues after elbow/lim/uim replacment
    Jan 2009
    san diego
    i would not ghetto rigify it with a ubend in the hose...i would use freeze plugs and plug the outlets coming from engine the right way. i found issue, not elbows at all. and NOW i started getting the tell tale sign of boiling coolant blowing pressure to the reservoir...just like i did in my talon a couple years back...parts sitting in box in car, just no time to put them on.
  4. #4 Re: coolant issues after elbow/lim/uim replacment
    You can't plug them. The coolant makes a circuit from the timing cover to the LIM. You'd need to put barbs in those two and run a hose.
  5. #5 Re: coolant issues after elbow/lim/uim replacment
    Jan 2009
    san diego
    good info to know. car is being a real *****. about to swap out for a new HD rad...the drain plug is stuck and wont loosen to drop coolant. tired of this car lol
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. coolant elbow replacement
    By reaper6 in forum General Tech Discussion
    Last Post: 07-26-2011, 07:15 AM
  4. coolant elbow replace
    By misterman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2010, 08:55 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
