Thread: Rod Knock or Lifter?
Results 1 to 20 of 32
  1. #1 Rod Knock or Lifter?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    My mom started are 01 GT and I hear this horrible sound which increased with RPM's that sounded a lot like rod knock or maybe a lifter or something not quite sure. Here is a video clip of the sound, my mom is freaking out about it because we don't have much money. Yesterday I also had to add some oil to it and it drove fine till today. Any help would be appreciated because I am not sure whats wrong. I'm thinking it probably isn't worth the money to fix because the Tranny is going bad in 3rd and 4th is surges when you add little throttle. Its has 160.xxx miles, rusted all to hell under it. Shame because its a Special Edition and I love the way it looks.
    Here is the clip:
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Rod Knock or Lifter?
    St. Louis
    Sounds like a lifter to me. Not deep enough to be a rod knock, at least not from the video. Grab yourself a long screwdriver and touch it to to motor in different spots and put your ear to the handle. Might be able to pinpoint the source this way.
  3. #3 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    Quote Originally Posted by FordMan77 View Post
    Seems to be coming mostly from left side of the engine near the belts and near the intake and front valve cover so Its looking more like a lifter or something. EDIT: More like a tick than a knock just started it again to hear around def coming from the upper portion of the motor.
    Quote Originally Posted by Kolton Lock View Post
    Also. See if the rpm level makes a difference. So have someone idle at 2k for a few seconds. If it goes away its not bottom end.
    I did this with some revs and it increased with the RPM's, but I'll try again holding at that RPM. Can't do anything with the belt till the weekend, I don't think its a bad pulley. EDIT: Just did that with the RPM's and it just made that sound but faster.
    2012 F150 STX
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    And and and and run the car without the belt, in park. If it stops making the noise, then you have a bad pulley. If it doesn't stop, then it's lifters or rod, or just something in the engine.
    My gt makes this noise, and even howls sometimes. But with 218k miles on it and the body rusted out, I'm not gunna bother
  5. #5 Re: Rod Knock or Lifter?
    HUDSON
    SOUnds like valve train, possibly rocker arm, broken valve spring, or worn valve stem. Pull the valve cover that it sounds like it is under and check for a loose rocker arm, with that much noise, it will be noticebly loose.
  6. #6 Re: Rod Knock or Lifter?
    Cambridge, Ontario Canada
    Check plugs first, make sure you don't have a cracked one making all that raquet. Check injectors they can make some strange noises. Check flexplate. Check under the valve cover as stated. Get a mechanics stetho or a long ass screwdriver.
    2005 E55 - stock
  7. #7 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    Okay so on my list of stuff to do this weekend includes:
    -Check Spark Plugs
    -Check Injectors
    -Check Flexplate
    -Check Valve Springs and Rocker Arms
    -Acquire long ass screwdriver
    Also crap ton of other car stuff wrong with my car I have to fix, this weekend is gonna suckkkkk. I'll get back here on the weekend with and news thanks for the help so far guys.
    2012 F150 STX
  8. #8 Re: Rod Knock or Lifter?
    St. Louis
    The flexplate is sandwiched between the motor and torque converter of the trans. If you take a look at the trans on the bottom edge there is an inspection plate that you can remove and see a bit of the flexplate. This is what the starter hits to turn the motor over. Also been called a flywheel.
  9. #9 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    Would injectors make a sound that loud? This is video I looked up: Broken flexplate Grand Prix GTP - YouTube sounds identical to me but, I'm really thinking valvetrain because of location and because I don't want to pull the motor with it being this cold, garage having no room even when empty, never done it before and no hoist. But hey gives me a reason to fix the leaky everything on the motor lol.
    2012 F150 STX
  10. #10 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    Thanks FordMan,
    If It was the flexplate the sound would be more to the right side of the engine and not the left side right? I looked up a video and it sounds identical to someone with a bad flexplate but I belive the sound is coming more from the left side for me.
    2012 F150 STX
  11. #11 Re: Rod Knock or Lifter?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    This sounds nothing like a flexplate, it really sounds like it is valvetrain related or even injectors.
    But it also sounds nothing like rod knock to me, when mine spun a rod it was a sound I recognize everywhere now, it just is that bad.
    011-4.mp4 Video by devenaroo | Photobucket flex plate sounds like that.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  12. #12 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    Thanks again, will report back this weekend (when I have the garage heater because freezing weather sucks).
    2012 F150 STX
    Emm not the flex plate. I agree with valve train related I would pull the valve covers and rockers and take a look at the springs. I doubt its a lifter I never heard one get that loud before.
    04 Comp G.
  14. #14 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    I'm still gonna check the belt, the car will run with the belt completely off right?
    2012 F150 STX
  15. #15 Re: Rod Knock or Lifter?
    Pennsylvania
    Left side? Maybe your tensioner's noisy?
  16. #16 Re: Rod Knock or Lifter?
    yes, but dont run it to long, or drive it, it can over heat.
    sounds like a rocker or bad lifter from here too. pop that valve cover off and check it out.
  17. #17 Re: Rod Knock or Lifter?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Check the oil. If it's like like barbie glitter then it's a rod bearing or you're grinding down the cam with a bad lifter. If it is not you are looking for something lift up in the valve train.
    97 Bonneville SE Not so much a 97 anymore
  18. #18 Re: Rod Knock or Lifter?
    With the belt off check all the pulleys and everything. Really bad water pumps can make a heck of a racket.
  19. #19 Re: Rod Knock or Lifter?
    FWIW when referring to a car, the headlights are the eyeballs and the grill is the mouth. Passenger = right, Driver = left.
    Tossing that in there if you ever need to buy something that is side specific like a caliper.
  20. #20 Re: Rod Knock or Lifter?
    Apr 2012
    Dayton, OH
    Thanks I was referencing if I was facing the front of the car so opposite....wups, I feel smart now
    2012 F150 STX
  1. How can you tell if a lifter is bad
    By Eric Whitter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2013, 06:45 PM
  2. Lifter noise
    By jonyaniro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2012, 08:32 AM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
  5. Colapsed Lifter?
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 08:48 PM
