Thread: Engine gets a little warm at idle and no heat till I rev it up
Results 1 to 16 of 16
  1. #1 Engine gets a little warm at idle and no heat till I rev it up
    Jul 2010
    Philly
    On my 03 GT with 100k on it. Like the topic says, heater blows cold and engine gets a little warm but if I rev it the temp drops and heat comes back. I'm thinking its the water pump, what you guys think? Anyone got a write up handy on how to replace it?
  2. #2 Re: Engine gets a little warm at idle and no heat till I rev it up
    St. Louis
    Personally, it sounds like a clogged heater core/cooling system to me. Think about the flow. At idle the pump is turning slower, so flow is lower through the core, even more so if it is clogged or partially clogged. Then when you rev it the flow rate increases and pushes more through the core, thus increasing the heat you feel inside. The temp dropping on the gauge is normal to me. Increased RPM's=flow=more cooling=gauge drops.
    That's just me thinking outloud. Never had a pump fail to push coolant, usually they just wear out the bearing or leak externally.
    Then only other thing that comes to mind is air in the cooling system. You don't have a leak anywhere do you? Disturbed the cooling system lately? My 00 GT used to do this and flushing then bleeding the system fixed it. I have great heat even at idle and the temp stays where it should.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    If it doesn't get warm probably a thermostat, probably a good time for a flush when u change it.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Could be as simple as low coolant.
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  5. #5 Re: Engine gets a little warm at idle and no heat till I rev it up
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    air pocket in the system?
    2009 mazdaspeed3-self tuned Cobb AP,Custom water to air IC,3" intake, 3" DP' 3" exhaust, Forge Wg actuator, Ricer mods, Cobb suspension
    2004 mazda 3-custom big turbo kit, blew up 4x went back stock (Details/pics ask)
    1997 GTP S/C 3.4 pulley, intake, all i know so far.
  6. #6 Re: Engine gets a little warm at idle and no heat till I rev it up
    Jul 2010
    Philly
    Thanks guys, over the summer I was flushing the coolant system with water to get dex sludge out of the system. Maybe I got an air pocket in the system. Ill try bleeding it tomorrow. Just seems strange that I had good heat last week but now I only get it above 3k.
  7. #7 Re: Engine gets a little warm at idle and no heat till I rev it up
    St. Louis
    Before you bleed it, with the car cold pop the cap and make sure it's full on coolant, and check the resevoir as well. If both are full, then bleed away. If not then top them off.
    If low you could have an external leak somewhere, or the LIM gaskets are leaking internally if they have never been changed.
  8. #8 Re: Engine gets a little warm at idle and no heat till I rev it up
    Jul 2010
    Philly
    LIM never been changed, was planning to do it this summer. Oil looks good at the moment. Did have to add coolant but I normally do a week after I flush out the coolant. Ive been flushing clean water to get the dex sludge out. Last week it got anti freeze for the first time.
  9. #9 Re: Engine gets a little warm at idle and no heat till I rev it up
    Dec 2012
    Aurora, IL
    i bet its a air pocket. makes sense for when he gives it gas it gets warmer.
  10. #10 Re: Engine gets a little warm at idle and no heat till I rev it up
    Jul 2012
    Chicago
    My vote is air in the system. Get those LIMs done ASAP if you think they're leakin'.
    -Carl
  11. #11 Re: Engine gets a little warm at idle and no heat till I rev it up
    Jan 2013
    United States
    i have a 2007 Grand Prix with the exact same problem. it has 70k miles on it and still has engine and transmition warranty from the dealership that i bought it from not even a month ago. if i floor it then it will cook me, but at idle or just driving like a normal person i get little to no heat. its warm but not warm enough to heat the car up.
  12. #12 Re: Engine gets a little warm at idle and no heat till I rev it up
    St. Louis
    sevenhellz- Try bleeding the cooling system and see what you get.
  13. #13 Re: Engine gets a little warm at idle and no heat till I rev it up
    GT Level Member GMCustomerService's Avatar
    Michigan
    Quote Originally Posted by FordMan77 View Post
    sevenhellz,
    Have you had the vehicle inspected for this issue? I agree with “FordMan77”, he offers a good suggestion.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  14. #14 Re: Engine gets a little warm at idle and no heat till I rev it up
    Jul 2010
    Philly
    Seems like it was an pocket. Got under the hood today (so cold out!). The rad cap was ice cold even after driving home from work (about 50 min drive). Though that was odd, reservoir was filled as well. Top rad hose was also hot. So what I did was toke a large towel and placed it over the red cap and removed it. The engine was still hot at this time. When the seal gave way I got about 2-3 secs of air hiss before hot coolant came out. Cranked it back down and on the drive to work tonight the heat worked fine and the temp didn't go or down with RPMs. Problem solved!
    Disclaimer! Never remove rad cap while engine is hot it will burn you up!
    Also when I went to close the hood the latch was forzen, guess thats what 11 degrees does to it lol. Got that fixed with a little WD40
  15. #15 Re: Engine gets a little warm at idle and no heat till I rev it up
    St. Louis
    Yea, removing the cap with the engine off and hot is a good way to evacuate the contents of the cooling system rather quickly, lol.. been there done that. Makes a mess of everything and coats the belt and pulleys in coolant too. Good that you have heat again. You may want to try this again once the motor is cold (like let it sit overnight) and then top it off if need be.
    Oct 2011
    MI
    Your heater core is clogged. Pull off the hoses blow some compressed air through it and watch the sludge come out
  1. ROUGH IDLE when Warm STILL :(
    By wilk84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 07:41 PM
  2. luke warm heat
    By Wingsfreak9 in forum General Tech Discussion
    Last Post: 03-01-2012, 03:57 PM
  3. Luke Warm Heat
    By mykp13 in forum General Tech Discussion
    Last Post: 02-04-2012, 01:56 PM
  4. Warm engine won't idle.
    By Jaybird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2010, 04:51 AM
  5. Engine runs fine till temp starts to rise...
    By 97gpGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 11:22 AM
