Thread: Rough start problems
Results 1 to 6 of 6
  1. #1 Rough start problems
    Oct 2012
    Kansas
    2005 Grand Prix. When the car is cold it starts just fine but after it has been warmed up you have to press the gas pedal to get it to start. I am going to try and clean the throttle body but has anyone figured out what is causing this on so many cars. I have changed the plugs and wires and it didnt help at all. There is not an external fuel filter or regulater on this car so I want to try to figure it out before replacing the fuel pump. Also when I take off its a little hesitant and then you can feel it take off pretty quick. Any ideas would be great. I dont know a whole lot so please explain pretty good
  2. #2 Re: Rough start problems
    Oct 2012
    Kansas
    I should also add that i have already cleaned the maf and air filter
  3. #3 Re: Rough start problems
    Clean the tb
  4. #4 Re: Rough start problems
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Throttle body is caked up with carbon and junk. Since it's a drive by wire system, the carbon buildup is preventing the throttle plate in returning to absolute zero and gives a false reading to the ECU.
    Clean the throttle body and everything will be good.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  5. #5 Re: Rough start problems
    Oct 2012
    Kansas
    Ok thanks for the help. I cleaned the tb and good thing i did. It was nasty. I also seafoamed it. Now it is running way better. Now on to figuring out what this whineing is when i start the car
  6. #6 Re: Rough start problems
    St. Louis
    Whining could be low power steering fluid, the transmission, or just the alternator. I noticed that on my 00 GT now that it's cold out the alt whines a bit more than normal at cold startup and voltmeter shows a little higher than normal until it warms up.
  1. rough start
    By honda237 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2011, 08:58 AM
  2. rough start
    By mosley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2011, 01:15 PM
  3. Rough start
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 10-22-2010, 05:12 PM
  4. Rough start-up
    By DanGTP in forum PCM Tuning
    Last Post: 02-08-2010, 12:16 AM
  5. Rough Start
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2009, 11:56 AM
