Thread: Rough Start
Results 1 to 7 of 7
  1. #1 Rough Start
    SE Level Member Willthesage's Avatar
    Feb 2009
    South Carolina
    I have recently bought my grand prix and enjoy it to death.
    However, I noticed a few times not all the times though that at start sometimes it doesnt like to idle. It will just die out. The only way around this is if I hold the rpm's at like 1,000 for just a few seconds for the engine to catch.
    It runs fine after that. Sometimes if I get the rpms to about 2,000 it starts acting as if it has hit the rev limit cause it starts buckin.
    I took the car to Autozone to get the SES light checked and it read my Throttle Possition Sensor was bad and my Camshaft Position Sensor was bad.
    Now im hopeing that would be whats causing the issue because if so i will get those both fixed next week come pay day. If not i will still get them fixed but i will also look for what ever the problem may also be.
    So if anyone has had this issue before please let me know.
    Also....
    Is it normal for sometimes when you idle to hear a gurgleing sound?
    It sounds right about in the middle of the car, im assuming a hole in the exaust pipe but not to sure havent been under the car to look, just thought i would ask.
    Thanks a bunch.
  2. #2 Re: Rough Start
    Feb 2009
    South Carolina
    No ideas anyone?
  3. #3 Re: Rough Start
    SE Level Member Kluke's Avatar
    Michigan
    I had the same problem with my 2004 and cleaned the throttle blade and body with carb cleaner i have not had a problem sense
  4. #4 Re: Rough Start
    SE Level Member 04muscle's Avatar
    Dec 2008
    British Columbia
    Kluke, any further info on what and where the throttle blade is?
  5. #5 Re: Rough Start
    TDCRacing
    Guest
    Yes those problems you currently have def. Could cause those symptoms that you also currently have. Try cleaning the Idle Air control passage out with carb cleaner also. It's the little motor looking thing the throttle body.
    The throttle blade is inside the throttle body. It's the butterfly looking thing. It will more than likley be black but after you clean it it will be brass looking.
  6. #6 Re: Rough Start
    Michigan
    yeah it was amazing what a little carb cleaner did to the blade and to my starting problems
  7. #7 Re: Rough Start
    Feb 2009
    South Carolina
    Okay thanks a bunch. I will go snag some from autozone here in a little bit and see if that helps.
    One other question could that cause the car to completely stall when i shift into drive on the occasion?
    Its only done it to me twice in the last i dont know 2 weeks or so.
    So its not something i worry about happening, but it has happened none the less.
  1. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
  2. oil light on and runs rough
    By 513yj in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2009, 09:20 PM
  3. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  4. Rough Start from stop....????
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 06:56 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
