Thread: Problems
Results 1 to 13 of 13
  1. #1 Problems
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Ok so theres two studs that come out of the heads on a gt for the engine mount. Do i put both them same two in the GTP heads? Im asking because i cant find a nut that will fit so i can tighten my supercharger tensioner up to the bracket. Also are the E.G.R bolts m8x1.25 in size? The ones that connect to the downpipe and LIM. Please help id really like to get my car done soon its killing me.
  2. #2 Re: Problems
    Yes, the studs are the same. On that nut. It's a specific nut, 13mm with almost no shoulder. This allows it to fit into the hole. Many other nuts on the engine are the same, but have a big shoulder. I have ground off the shoulder of a normal nut to use it in that position when the nut has become lost.
  3. #3 Re: Problems
    Dec 2011
    Decatur
    So if i take a exhaust nut would it fit?
  4. #4 Re: Problems
  5. #5 Re: Problems
    Dec 2011
    Decatur
    Ok, then where can i get a new one?
  6. #6 Re: Problems
    If you look at the size of the stud vs exhaust ones, you'll see why it won't fit.
    That stud IIRC is a M10 by 1.50 thread. Find yourself a 13mm nut with the M10 hole, then grind the shoulder off it. There's maybe only two 13mm nuts with an M10 hole on the entire car. I don't know what the nut comes from besides the tensioner, but I know I've had 2-3 when in a jamb that were in my piles of spare parts. Keep in mine..100's of cars roll through here.
  7. #7 Re: Problems
    Dec 2011
    Decatur
    So its gonna be hard to find? Yea i noticed that after i asked.
  8. #8 Re: Problems
    IMO it's easy to find. Hit any JY where there's a GTP, Regal GS, Impala SS with SC or Monte SS with SC.
    Any W body car with an sc has this nut.
  9. #9 Re: Problems
    Dec 2011
    Decatur
    ok thanks ill look today when i get off
  10. #10 Re: Problems
    Ps..bring your 13mm socket with you.
  11. #11 Re: Problems
    Dec 2011
    Decatur
    I got it!!!
  12. #12 Re: Problems
    Dec 2011
    Decatur
    Whats the bolts size for the bolts that connect the BBV to the supercharger?
  13. #13 Re: Problems
    A supercharged car has no BBV, that's a turbo thing.
    The BCA aka Boost Control Actuator is held to the SC with two 10mm bolts. They are about 3/4" in length. FWIW if you took pics of all your spare bolts, we could tell you exactly where to put which bolts.
  1. hid problems
    By jspangler22 in forum Visual/Body Modifications
    Last Post: 05-13-2011, 05:29 PM
  2. Rpm problems?
    By 69prixguy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2011, 12:39 PM
  3. ABS, TCS problems?
    By astros2900 in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2011, 07:27 PM
  4. 2 Problems
    By Vapour1ze in forum General Tech Discussion
    Last Post: 10-12-2010, 12:24 PM
  5. Pcm problems
    By Mje00GPGt in forum PCM Tuning
    Last Post: 09-27-2010, 07:35 PM
