Thread: Engine Codes P0171 and P0102 need help
Results 1 to 9 of 9
  1. #1 Re: Engine Codes P0171 and P0102 need help
    Dec 2012
    Redlands, CA
    Hi, I have a similar problem as I first had a P0102 code. I actually replaced my MAF sensor with a used one from the junkyard. It came of a 3.8 Camaro and the part numbers matched. After installing it, it threw another code P0171 which to my understanding is also MAF related. Should I just buy a brand new one? I'm really trying to save myself a $150 investment. I recently replaced all the vacuum hoses and checked for leaks.
    Before replacing the MAF the car ran fine but would stall only in cold and high moisture conditions. I did the unplug test, with no difference. That told me that I needed to replace the MAF. Now the car is idling rough, but not stalling anymore. Thus, giving me P0171.
    *Note: 1999 Pontiac Grand Prix GTP (VIN "1")
  2. #2 Re: Engine Codes P0171 and P0102 need help
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Here is how to check with a meter :
    Part 1 -MAF Sensor Test: GM 3.3L, 3.8L
    1997 Red GTP 182000 miles stock
  1. Check Engine Codes P0120, P0113 and P0171
    By 71gs3504sp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2012, 12:00 PM
  2. P0171, P0440, P0443 codes
    By stevenj in forum Engine
    Last Post: 10-29-2012, 09:29 AM
  3. Code P0171 and P0102
    By Kelime in forum General Tech Discussion
    Last Post: 11-17-2011, 05:26 PM
  4. Need help finding out what i need to fix! P0303 and P0171 codes
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 08:45 PM
  5. PLEASE HELP! Codes P0102 & P0452
    By TAWinner23 in forum General Tech Discussion
    Last Post: 09-17-2008, 02:11 PM
