Thread: Check Engine Codes P0120, P0113 and P0171
Results 1 to 16 of 16
  1. #1 Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    Hi
    A week ago my MAF code was on and I replaced the MAF sensor because it was crack on the top of it.
    Engine ran great, MAF code went off after 5 miles, then for the next 150miles.
    When I hit 150 miles P0102, P0113 and P0171 codes came on. No change due to the engine idled and ran great. I checked all the connections and cleared all the codes. Drove 30 miles so far and no codes yet.
    Can someone help me here.
    George
  2. #2 Re: Check Engine Codes P0120, P0113 and P0171
    George...would you list out the names for the codes. I think I see maf in there...
  3. #3 Re: Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    P0102 Mass or Volume Air Flow A Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0171 Bank 1 System to Lean
  4. #4 Re: Check Engine Codes P0120, P0113 and P0171
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Do you happen to have a K & N oiled air filter ?
    1997 Red GTP 182000 miles stock
  5. #5 Re: Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    I believe I have a K&N filter in there, its been in there a long time!
    Since I cleared all the codes and then driving over 75 miles today one code came back.
  6. #6 Re: Check Engine Codes P0120, P0113 and P0171
    You got a vacuum leak somewhere.
  7. #7 Re: Check Engine Codes P0120, P0113 and P0171
    GTP Level Member
    Oct 2011
    Raleigh, NC
    x2 on the vac leak, also either clean and re-oil the filter or replace with a paper one.
    If those are overoiled they can throw the MAF off and proly mess with the intake air sensor.
  8. #8 Re: Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    Guys thanks for all your suggestions.
    I checked all the vac connections and one had a little crack on the end.
    I cut about a 1/8" off of it and the check engine light went off.
    I can't believe how small of a cut it was that will set off the check engine light.
    Thanks again, George
  9. #9 Re: Check Engine Codes P0120, P0113 and P0171
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    My car started throwing the System too lean bank 1 (P0171) and the Mass or Volume Air Flow Circuit Low Input (P0102) codes yesterday. Runs rough at times and misses it feels like. Also will stall out at idle and when I let off of the gas sometimes. I cleaned the MAF sensor less than a month ago so I feel that shouldn't be the issue. I will probably check for a vac leak but I'm not sure what is best to use for it and of course nobody is open on Thanksgiving. I have also heard the the O2 sensor could be bad as well. Is there any way I can check that myself?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  10. #10 Re: Check Engine Codes P0120, P0113 and P0171
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    I finally picked up a OBDII Scanner the other day. I had recently put a can of Seafoam into the tank of the GT, just to keep things clean. Of course, after about 10 miles on the highway back, my CEL lit up. The car ran perfectly before and after the light came on and the car was checked before putting the Seafoam and it had no codes stored or otherwise. So was it coincidence? Not sure about that. Anyhow I picked up an Actron CP9575 for $70 bucks on Ebay, just to have for myself rather than having to pay someone to diagnose the car. I hooked it up yesterday and It had one code (P0171) Bank One Too Lean. I erased the code and reset the CEL. I'll go down today and spray the vacuum lines and the intake manifold with some WD-40 to see if I have any leaks. I have to say that the Reader was well worth the money.
    2002 GT Red, Stock, Work In Progress..........
  11. #11 Re: Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    Guys
    My P0102 Code showed its self again.
    Car is running normal, the code goes off onces in a while, and now on again.
    I did replace my MAF a few months ago, since I know it needed replacing since it was cracked.
    The code reader recommends the following for its fix.
    1. Replace MAF
    2. Replace EGR Transfer Tube
    3. Replace Fuel Pump
    What do you guys think and please let me know what to look for to fix it.
    George
  12. #12 Re: Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    ttt
  13. #13 Re: Check Engine Codes P0120, P0113 and P0171
    George, your new maf is likely crap.
  14. #14 Re: Check Engine Codes P0120, P0113 and P0171
    Aug 2011
    Bucks County Pa
    Bill
    Is there a way to check the MAF if its crap?
    I purchased it at Autozone because it is the only one with a lifetime warrantee.
    BTW Bill thanks for all your knowledge on these 3.8 motors!
    George
  15. #15 Re: Check Engine Codes P0120, P0113 and P0171
    George, it's more experience in watching all you poor suckers with AZ lifetime guarantees drive their daily for a new one. For some reason they often fail in the car.
    It's like putting in Bosch plugs. They'll run fine for a few minutes and then torture you into submission. That's why I convinced DSmutty to sell me his spare out from under Danielle when mine when bad. Maybe check car-part.com and get a factory one.
  16. #16 Re: Check Engine Codes P0120, P0113 and P0171
    Or get ahold of someone @ Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    They've been in the game quite awhile.
  1. P0171, P0440, P0443 codes
    By stevenj in forum Engine
    Last Post: 10-29-2012, 09:29 AM
  2. Check Engine light came on today with 4 codes.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2011, 12:12 AM
  3. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2009, 08:12 PM
  4. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:34 AM
  5. Check Engine Light on - Codes included
    By jcapone in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 02:04 AM
