Thread: Temperature Problems
Results 1 to 20 of 77
  1. #1 Re: Temperature Problems
    Feb 2008
    West Jordan, UT
    Trace, as in checking to make sure that none of them are frayed or ripped out or anything? No I didn't.
    And the fans have three relays. The two that were the same size I was able to swap. The third, I don't know about.
  2. #2 Re: Temperature Problems
    TDCRacing
    Guest
    Quote Originally Posted by spenc938 View Post
    Well i'd start there. see if you cant pick up a new relay like that and let us know.
  3. #3 Re: Temperature Problems
    SE Level Member jpopdallas's Avatar
    Apr 2009
    U.S.A
    I'm having this same issue with my 06 grand prix. Both fans only work with a/c on. I have replaced all the relays and new stat. I'll be replacing my temp sensor in am but after looking at your post my spirits are lowered. I checked the wiring aswell. No freys or messed up wiring. GRRRRRRRRRR.
    Frustrated big time. I'm sure somebody had this same issue and will help us out.
  4. #4 Re: Temperature Problems
    Feb 2008
    West Jordan, UT
    Quote Originally Posted by jpopdallas View Post
    Don't count on it. I've had this problem for I think about seven months now. I tried everything people suggested with no results, and eventually people just stopped replying. Both in the forums and in PMs.
  5. #5 Re: Temperature Problems
    Apr 2009
    U.S.A
    when you did the intake gasket did you notice if the coolant holes were plugged and was the coolant used dex cool? I've read that air interacts with it and make sludge build up in your system. I have an 06 with only 43,000 and mine started to give wierd temp signes. Looked at my rad cap and damn 1/2 inch of sludge was on the bottom of it. Did a good flush used a super cleaner and fiiled up with non dex-cool and so far all is good.
  6. #6 Re: Temperature Problems
    Feb 2008
    West Jordan, UT
    It is dex cool, but it's in really good shape. The coolant passages are fine. The cooling system works great when the car is moving, but it's sitting in traffic when there is no air flow that is the problem. Even worse than sitting is climbing hills at low speeds...
  7. #7 Re: Temperature Problems
    Wessington Springs, SD
    I have the same problem here...my fans will only run when the air conditioner is on and the car is in park...they will not work when the car is driving period...what in the hell is going on here?? i have an 04 gt1...
  1. ICM Problems??
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2009, 12:53 AM
  2. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
  3. Many problems/ Please help
    By Vurelis in forum General Tech Discussion
    Last Post: 06-15-2008, 03:45 PM
  4. HUD Problems
    By 03GTPFour in forum General Tech Discussion
    Last Post: 03-09-2008, 10:38 PM
  5. Temperature sender location
    By bat119 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2008, 09:23 AM
