Thread: Lifter noise
Results 1 to 8 of 8
  1. #1 Lifter noise
    SE Level Member jonyaniro's Avatar
    Oct 2012
    rochester ny
    Hello im new on this forum but like it so far.
    I have a question about lifters. i had an oil change done recently and the technician ran the car without oil (about 30-40 seconds). i usually do my own oil changes but if i dont have time i just pay for them. since then Ive had lifter noise that is very apparent. i have talked to the shop but no help so i give up. i just need general advice on possible damage... and replacement of the lifters. i have never done them before is the process relatively easy or does the whole cam have to come out?? Are there additives to help quiet the noise... any advice is helpful to me.
    im fairly mechanically inclined but i would like help from fellow 3800 owners that may have experienced this. thank you.
    car has 130,000 and i use valvoline maxlife synblend with a quart of lucas.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    If it was caused by the shop, I would be going after $ to help pay for the repair. Lifters only require pulling the lower intake and valve covers. Then unbolt your rockers, pull pushrods, replace lifters. Get new rocker bolts as they are tty. Remove fuel pump relay and crank then engine until the oil pressure light goes off, this will help prime the lifters before you start it.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Lifter noise
    There is a video of lower intake gaskets. (Scotty will be along soon with a link, he's got them all) The job is basically LIM gaskets and valve cover gaskets combined. Add in the rocker bolts and then the lifter plastic retainers and you'd be done. Very straight forward on our motor.
  4. #4 Re: Lifter noise
    making me work on my days off lol
    here ya go.
  5. #5 Re: Lifter noise
    Surprised it took you so long.
  6. #6 Re: Lifter noise
    i was out helping a friend take his 4 cats to the vet. fun morning.
    at least the kittens are still small and cute.
  7. #7 Re: Lifter noise
    Aug 2012
    MA
    When you say a quart of Lucas, what exactly is the product? Also what weight oil.
    08 Pontiac Grand Prix 3.8L 95k M1 0w40, FRAM ULTRA
  8. #8 Re: Lifter noise
    lucas transmission stop slip VVVVVVV this you can just add to the trans, or use it when you service your trans. such as a pan drop and filter change.
    for oil use what ever it says on your oil cap for oil. or in the manual. 10w 30, or 5w 30 usually.
  1. Acid's 2005 Top Swapped GT: S2X Cam Install
    By acidcrashdburnd in forum Members Rides
    Last Post: 05-11-2013, 02:58 PM
  2. Lifter/ticking noise???
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2010, 12:43 PM
  3. loud lifter noise any ideas?
    By breeze12 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 02:12 PM
  4. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
  5. Ticking noise, thinking lifter
    By bradford82 in forum General Tech Discussion
    Last Post: 01-25-2009, 10:44 AM
