Thread: loud lifter noise any ideas?
Results 1 to 5 of 5
  1. #1 loud lifter noise any ideas?
    ohio
    hi
    just got a 2001 gtp 107k mi purchased at auction probably repo, car runs out good everywhere else pulled a code po306 changed the plug, has great spark yet missing on that cylinder. so it runs rough with a loud lifter noise in the back bank. engine seems to be very sludgy. lifter noise goes along with the engine rpms. any help with step by step procedures to narrow it down thanks
  2. #2 Re: loud lifter noise any ideas?
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    did you replace the wire? if it's a ticking noise it could be a bad wire.
  3. #3 Re: loud lifter noise any ideas?
    ohio
    no, didnt replace wire. I have spark to the plug. its also not that kind of ticking. its more of a loud clattering in the top end, the po306 code is a hard fault code, comes back right away. I have run engine flush to try and dissolve sludge not much help. thanks probably going to have to remove the valve cover. wondering on the difficulty level.
  4. #4 Re: loud lifter noise any ideas?
    May 2008
    McHenry IL
    if u have basic hand tools your good... good luck bro
  5. #5 Re: loud lifter noise any ideas?
    ohio
    wow! what a dead forum, but thanks for all that replied
  1. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  2. Loud Rattling Noise
    By Dangerous313KidInAPrix in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 05:18 PM
  3. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
  4. Ticking noise, thinking lifter
    By bradford82 in forum General Tech Discussion
    Last Post: 01-25-2009, 10:44 AM
  5. Loud noise above 45mph
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-09-2008, 10:03 PM
