Thread: Going cam'd...need opinions.
Results 1 to 20 of 33
  1. #1 Going cam'd...need opinions.
    GTP Level Member apierce1289's Avatar
    United States
    Alright I want to go cam but I want to get a cam that has a good HP boost and will be a good candidate for a turbo. Don't know too much about camshafts so is the higher the lift the better?
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Buy a turbo cam then
    United States
    Quote Originally Posted by Kolton Lock View Post
    But I want to learn I want to know what that stuff means. I'm a noob about cams.
  4. #4 Re: Going cam'd...need opinions.
    see what others have used and with what sort of success.
    United States
    Looks like I'm going to buy the stattam 5 Turbo cam. Go big or go home. That things a monster cam. The install will probably suck though. Lifters, cam, and double roller timing chain.
    Ohio
    Typical... Easy way out.
  7. #7 Re: Going cam'd...need opinions.
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    if you want to go big, you could get a custom ground cam if you do some head work
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
    Ohio
    Actually... The stage 5 you should do head work with..
  9. #9 Re: Going cam'd...need opinions.
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    When I started looking to cam my engine, I googled cam numbers explained..just keep researching and you'll get a better understanding of what a cam does, what the spec. numbers mean, and which one best suits your build goal.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  10. #10 Re: Going cam'd...need opinions.
    Since its the internet, you'll get a lot of conjecture.
    Ohio
    Tis truth he speaks
    United States
    I was thinking about getting a cheap motor from Ed Morad (morad parts). Would it probably be easier to build this on a stand and then swap the motor into the car? I've never done lifters or a cam. The most I've done is help Bill with my headers. So I was thinking about getting a cheap engine stand (duralast one for $100 at autozone) to build it on. And then a cheap crane. That way I keep my daily and build this in the garage. Also what should I tell Ed that I'm looking for? Or will it not matter since I'm rebuilding the whole thing?
  13. #13 Re: Going cam'd...need opinions.
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    Start with a nice L26, and build away
    Ohio
    Quote Originally Posted by BrendanMurphy View Post
    LOL
    Are you on drugs?!
    L26 is a failure.. A major failure for any boosted setup..
    Op... Just get a somewhat low mileage l36 from morads and build it.
  15. #15 Re: Going cam'd...need opinions.
    On learning about cams. Read until your eyes bleed a few times and you'll know more than most here. From there you can gauge what times people have run with various setups and how things have idled etc. Read the turbo sections on the forums and see what issues etc people have had. This is the way I research things when I have questions or am interested in something different.
    On the lifters, timing chain etc etc. All those things are easy, look at each as individual steps and it really is simple. The first part of the build is to remove the intake and valve covers. Then pull the rockers, remove the pushrods (just sitting there once rockers are removed. Four more bolts and you use a magnet to help get the lifters up. Or if you have relatively low mileage..remove teh rockers, push rods and leave the lifters in...put the motor upside down and they'll be out of your way.
    I have a decent 4 wheel engine stand that came from Harbor Freight ~$50 during one of their nearly daily sales. Engine hoise ~$150.
    United States
    Are there any write ups on how to install a camshaft? Except I'm doing mine on an engine stand.
  17. #17 Re: Going cam'd...need opinions.
    remove lifters, balancer, cover, timing set, cam.
    Install cam, gears, timing set, make sure its lined up, timing cover, balancer, put together top end, explode a timing set or lifters or something cool.
    Last step optional, but expected.
  18. #18 Re: Going cam'd...need opinions.
    Jan 1970
    Maquoketa, Iowa
    I would get the turbo, a built transmission and then a cam. That way you can slowly work your way up. It's going to be one big chunk of change sitting around on engine stands or waiting to go into the car, you won't be able to run a st5 turbo setup without a $2,000-3,500 transmission in it. You may find that the turbo alone on a fwd setup is plenty of power anyway, or that it's too much money for a fwd car anyhow.
    United States
    Quote Originally Posted by FoSHO99 View Post
    I understand where you're comming from. But I'm doing this to learn and prove to myself that I can finish what I've always envisioned. To finish something I've told myself I can do and to do it. It may just be a Grand Prix but I feel its more personal then going and purchasing a Corvette or something else. You can see those everywhere there not even that special anymore cause just about every old geezer has one. But their all stock which is ok except that's all they are just stock! I want to build a monster and that's what I've set out to do.
  20. #20 Re: Going cam'd...need opinions.
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    I'm tearing down my engine now, vacuum and oil leaks like crazy! With that said, I'm going to rebuild with a cam of course. Have you got any good insight? I have no idea where to start...
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  1. Opinions on N* TB please
    By wpbboy81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 07:36 PM
  2. Is this really that bad? Need opinions
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-24-2010, 05:29 PM
  3. I need opinions
    By JESSEGOTTA GP GT in forum Visual/Body Modifications
    Last Post: 01-27-2010, 07:13 PM
  4. Opinions please
    By boomboom in forum Visual/Body Modifications
    Last Post: 07-29-2009, 08:17 PM
  5. Opinions?? First serious mod
    By bonerjamz03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 10:14 PM
