Thread: '05 GP GT 3800 Series III TB clean
Results 1 to 12 of 12
  1. #1 Re: '05 GP GT 3800 Series III TB clean
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by goochman View Post
    I havent found a good writeup on how to remove the TB on the L26 engine. There are a ton of writeups on the L36 TB removal. It appears if I do something wrong I could screw things up pretty badly. Your msg is the first Ive seen about harming the UIM if I just spray the TB cleaner in without removal - thats a good piece of info I havent seen on any other site.
    Its also noted above that if I disconnect any of the electrical connectors that I need to do a TB relearn - removing the TB means disconnecting everything?
    There are alot of threads on this subject but I havent really found a good DIY writeup w/pics for the L26 motor for newbies.
    Looking at it from above as an amateur it looks like I could screw something up badly
    Here you go.
    Grand Prixs Of North America • View topic - clean your MAF & Throttle Body
    GPONA #1 Cyber Bully
  2. #2 Re: '05 GP GT 3800 Series III TB clean
    Aug 2012
    DC
    Excellent - thanks! I dont have any Miller High Life, hopefully I can switch parts for that step and still be successful
    Basically cleaning the MAF, TB, and replacing the sparks/plugs and Ive completed the 'tune up' steps?
  3. #3 Re: '05 GP GT 3800 Series III TB clean
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Plus new oil, rad flush, and all the filters.
  1. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  2. 3800 Series III L26
    By michael152354 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 01:09 AM
  3. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  4. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
