Thread: '05 GP GT 3800 Series III TB clean
Results 1 to 12 of 12
  1. #1 Re: '05 GP GT 3800 Series III TB clean
    Aug 2012
    DC
    Quote Originally Posted by Rico View Post
    Correct
    So you're willing to spray all of that crap into the UIM?
    Why not remove it and clean it correctly?
    I havent found a good writeup on how to remove the TB on the L26 engine. There are a ton of writeups on the L36 TB removal. It appears if I do something wrong I could screw things up pretty badly. Your msg is the first Ive seen about harming the UIM if I just spray the TB cleaner in without removal - thats a good piece of info I havent seen on any other site.
    Its also noted above that if I disconnect any of the electrical connectors that I need to do a TB relearn - removing the TB means disconnecting everything?
    There are alot of threads on this subject but I havent really found a good DIY writeup w/pics for the L26 motor for newbies.
    Looking at it from above as an amateur it looks like I could screw something up badly
  2. #2 Re: '05 GP GT 3800 Series III TB clean
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by goochman View Post
    Here you go.
    Grand Prixs Of North America • View topic - clean your MAF & Throttle Body
    GPONA #1 Cyber Bully
  3. #3 Re: '05 GP GT 3800 Series III TB clean
    Aug 2012
    DC
    Excellent - thanks! I dont have any Miller High Life, hopefully I can switch parts for that step and still be successful
    Basically cleaning the MAF, TB, and replacing the sparks/plugs and Ive completed the 'tune up' steps?
  4. #4 Re: '05 GP GT 3800 Series III TB clean
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Plus new oil, rad flush, and all the filters.
  1. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  2. 3800 Series III L26
    By michael152354 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 01:09 AM
  3. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  4. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
