Thread: 3800 Series II MPG?
Results 1 to 11 of 11
  1. #1 3800 Series II MPG?
    Feb 2009
    WA
    Hey everyone,
    I have an '03 GT 4-door and I am not getting very good mileage with it (21-24 mpg with lots of highway driving). I used to get around 25-27 mpg (or better if it was all highway miles) with an '03 Impala LS with the 3800. I bought the GP used so I don't know what the gearing is because I don't have the original paperwork. And I don't know what the gearing was on the Impala either.
    I am guessing the gear ratios are different on the two cars and maybe that is why the difference in mileage? I am changing the sparks soon so maybe that will help. Also I had the K&N FIPK on the Impala and I have a Cold Air Induction CAI w/K&N on the GP. I am just curious what you guys are getting with your 3800s as far a mileage goes. Any tips on add-ons or driving styles would also be appreciated. Thanks.
    PGT
  2. #2 Re: 3800 Series II MPG?
    Barksdale AFB, LA
    3.29 gearing on your GP GT. 3.05 Gearing on a Impala LS.
    2009 Subaru Impreza WRX STI
  3. #3 Re: 3800 Series II MPG?
    Feb 2009
    WA
    Well, that would seem to explain it. Thanks Sabrewings.
    PGT
  4. #4 Re: 3800 Series II MPG?
    TDCRacing
    Guest
    Also cold air intakes will make you suffer on the MPG end. Hot air = more MPG's ......
    Also how are you keeping track of you're miles?
  5. #5 Re: 3800 Series II MPG?
    Feb 2009
    WA
    Quote Originally Posted by TDCRacing View Post
    Just dividing miles by how many gallons I fill up with at the pump.
    PGT
  6. #6 Re: 3800 Series II MPG?
    SE Level Member Coogles's Avatar
    I don't know how true that is. Maybe a HAI would be better, but when I had a stock GT my very first mod was a Wizair and I noticed my overall mileage jumped up by ~1mpg across the board.
    Forest Green 1998 GTP Sedan - SOLD
    VS, 3.2, TOG, GMPP Suspension, 3EP Tune
    13.179 @ 106.57 w/2.005 60'
  7. #7 Re: 3800 Series II MPG?
    TDCRacing
    Guest
    Quote Originally Posted by Coogles View Post
    Cold air is more dense with oxygen, therefore it will use more fuel to achieve the proper air/fuel ratio the computer is looking fo. Warmer air has less oxygen and will use less fuel to achieve the same ratio.
    You should try switching to an open cone and see how many you pick up
  8. #8 Re: 3800 Series II MPG?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    But with denser air, you need less of it to make any given amount of power. Add to that less pumping loss from having a a more freely flowing intake, and a CAI should increase your fuel economy.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: 3800 Series II MPG?
    Hoffman/Schaumburg, IL
    True in the winter, I lost about 1.5 mpg's in the winter running my wizaired, in the summer I gained .5 MPG,(both math, not DIC readings)
    If you want a hai, just remove the box for the winter, and re-install in the summer
  10. #10 Re: 3800 Series II MPG?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by 02BlueGT View Post
    Yep that's what I did, works great.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  11. #11 Re: 3800 Series II MPG?
    Feb 2009
    WA
    Yeah, I think I will just remove the clear lid and see what kind of mileage I get this go 'round. Thanks for the tips guys.
    PGT
  1. 3800 series 2 supercharged whine NOT NORMAL
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 02:13 PM
  2. 3800 series II Vin 1 - Pulley swaps
    By sledneck907 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 01:08 PM
  3. 3800 Series III 1/4 Mile
    By gp04 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 03:40 PM
  4. L32 (2004) 3800 Series III cover
    By mcg_999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 02:59 PM
