Thread: lower intake gasket job list
Results 1 to 18 of 18
  1. #1 lower intake gasket job list
    Dec 2011
    MN
    gonna replace the lower intake gaskets on my 2001 grand prix 3.8 NA
    gonna flush coolant at this time and get rid of the dexcool
    planning on replacing the coolant elbows also at the time
    was looking at this kit at autozone, is this everything I need?
    http://www.autozone.com/autozone/par...8_12080_142805
    thanks
  2. #2 Re: lower intake gasket job list
    You want the second one down. Part number # MS98014T
    Which is the metal/steel ones, AC delco uses aluminum, but same thing.
    You also want to buy 10 quarts of oil and a new filter, so you can wash away the coolant in the valley and to change it twice so you dont have internal engine problems.
    Where at in MN are you?
  3. #3 Re: lower intake gasket job list
    Omaha, NE
    I would also get some RTV if you don't already have some and a new thermostat.
  4. #4 Re: lower intake gasket job list
    Never Never Land
    I've always got the one cam listed. But I dont see anything wrong with the one you listed either.
  5. #5 Re: lower intake gasket job list
    yes sir that is everything you need besides the coolant, coolant elbows,oil, and oil filter, and rtv for the four corners when installing the Lower intake manifold. After you're done changing the lower intake gaskets and the job is complete make sure you drain your oil and refill with fresh. I go a little over the top and do my refill with a cheap oil, run the car for 5-10 minutes, then drain and refill with mobil 1. All up to you on how safe you want to be making sure all the coolant/water is out of your oil.
  6. #6 Re: lower intake gasket job list
    Dec 2011
    MN
    got it, changed to the felpro
    added thermostat to the list
    thanks
    making my girlfriend buy me this for doing the work for free
    OEM/120 LED corded under hood light (25991) | Work Light | AutoZone.com
    also the felpro doesn't include the upper, so do I need this too?
    Felpro/Intake Plenum Gasket (MS95812) | 2001 Pontiac Grand Prix 6 Cylinders K 3.8L SFI OHV | AutoZone.com
  7. #7 Re: lower intake gasket job list
    Yes, you'll need that too.
  8. #8 Re: lower intake gasket job list
    Dec 2011
    MN
    the intake isn't leaking just doing it as preventive measures
    So is the Felpro that much higher quality?
  9. #9 Re: lower intake gasket job list
    Dec 2011
    MN
    im in stillwater
    what else?
    so far
    felpro LIM
    felpro upper
    dorman intake elbows
    thermostat
    coolant
    oil/filter
  10. #10 Re: lower intake gasket job list
    You just want the metal style intake gaskets, so that way you never have to worry about them again.
  11. #11 Re: lower intake gasket job list
    Man, everytime I wanna help, people live so far away lol.
  12. #12 Re: lower intake gasket job list
    Omaha, NE
    You could always to plugs and wires if you wanted to add those to your list.
  13. #13 Re: lower intake gasket job list
    Dec 2011
    MN
    earlier this spring I put in all new plug and wires, rear brakes, outer tie rod ends, belt, air filter
    just finishing what I meant to do earlier
    She has been driving her jeep wrangler all summer long, this is the winter beater. Gettin a head start on this before winter hits. Always sneeks up on ya
  14. #14 Re: lower intake gasket job list
    If the valve covers are leaking, it's the perfect time to do them. I'd include a bottle of TB cleaner and take that off while you are at it. Like the upper, the gasket is reusable. Check that upper manifold in the EGR are to ensure it's not getting weak. If it seems weak, etiher plug the ports or replace upper.
    See my L36 UIM Failure thread for more info on the most common killer of the NA motor.
  15. #15 Re: lower intake gasket job list
    Dec 2011
    MN
    10-4 Billboost,
    thanks for the heads up!
  16. #16 Re: lower intake gasket job list
    Dec 2011
    MN
    thanks for everyone's help, job done and running good!!
    Couple tips I learned -
    buddy mechanic told me to put a good bead of black RTV sealant on the vally, then lay down the vally rubber gasket and lay another bead.
    Remember to transfer the little black hose on the upper plenum intake gasket
    other than that it was super easy compared to my ford powerstroke 6.0 oil cooler rebuild job haha
    Oh and one more thing, autozone had to special order both felpro gasket sets and did not have the dorman coolant elbows in stock.
    Oriely's had everything in stock!
  17. #17 Re: lower intake gasket job list
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    I went looking for that thread Bill, cause I will be doing the same thing, and I can't seem to find it...I know it used to be stickied...(shame it still isn't, was a GREAT write-up!)
  18. #18 Re: lower intake gasket job list
    Jul 2012
    Quote Originally Posted by bayus2972 View Post
    NVRMND...found it!!
  1. how do i know if my lower intake manifold gasket is bad?
    By asite57 in forum General Tech Discussion
    Last Post: 05-08-2012, 07:03 AM
  2. the best lower intake manifold gasket?
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 05:04 PM
  3. HELP!!! Lower Intake Gasket problems
    By ajc549FF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2011, 08:00 AM
  4. lower intake manifold gasket
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2010, 09:26 PM
