Thread: HELP!!! Lower Intake Gasket problems
Results 1 to 5 of 5
  1. #1 HELP!!! Lower Intake Gasket problems
    SE Level Member ajc549FF's Avatar
    Lake Zurich, IL
    So on my 98 GTP, my buddy and I did the lower intake gaskets today and we replaced all the gaskets along with the T-start and we cleaned the throttle body. We put it back together and everything went slow but okay the only thing we really ran into is that there is this black piece ontop of the supercharger thats circular that has 3 nipples coming out of it and one of them broke off. We couldn't get it back together and my buddy thinks its a vaccum of some sort. We followed the line it ran to the passenger side wheel well and then ended right below the fuse Box and we have no idea where it could go, or do. So we started it up everything connected and in place we had the bad line taped just for a temporarly fix and it started , sounded like it had a a cam we cut the engine did it again and it knocked a little, not like a true knock but a light ticking noise so we pluggged up the bad line right at the start of it and started it again and same thing. So any ideas what this could be?
    Thank you in advnaced, I know this is long and thank you for reading this if you did, I just really need to get my car running back to normal.
    98GTP 3.5in tips, headers, fenderwell intake, 180tstat...3.5pulley?
    1984 Four Winns (Boat) 190 Horizon 19ft open bow...new 350 soon! and Thru Hull exhaust!
    03-07 Duramax Diesel next summer after paramedic is finally over!
  2. #2 Re: HELP!!! Lower Intake Gasket problems
    that would be the BBV, and you broke it, and its part of the car major vacuum lines. It will run very lean and may not run at all. You need to replace that.
  3. #3 Re: HELP!!! Lower Intake Gasket problems
    Lake Zurich, IL
    What would that look like? And where would it be located?
  4. #4 Re: HELP!!! Lower Intake Gasket problems
    Minnesota
  5. #5 Re: HELP!!! Lower Intake Gasket problems
    Ok.. it's not the BBV, because first ...we don't have one, secondly that middle port goes to the vacuum canister. It heads below the fuse box, then heads across the front of the car to the driverside fender where the canister is located.
    You need that vacuum manifold (what it's called). Til you get it, plug that hole.
    On the cammed sound. Please recheck your plug wires, two are on the wrong cylinders. Don't ask how many times I've done it, to know what to check..just laugh and go check yours. It's an easy fix.
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. help with Lower intake.
    By white2002gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 09:31 AM
  3. lower intake manifold gasket
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2010, 09:26 PM
  4. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  5. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
