yes sir that is everything you need besides the coolant, coolant elbows,oil, and oil filter, and rtv for the four corners when installing the Lower intake manifold. After you're done changing the lower intake gaskets and the job is complete make sure you drain your oil and refill with fresh. I go a little over the top and do my refill with a cheap oil, run the car for 5-10 minutes, then drain and refill with mobil 1. All up to you on how safe you want to be making sure all the coolant/water is out of your oil.
