Thread: Chugging?
Results 21 to 40 of 47
  1. #21 Re: Chugging?
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    Would a bad cat through a code though? I mean, it's pretty bad.
    -ljmonnin12
  2. #22 Re: Chugging?
    Aug 2012
    Doylestown,PA
    My car didn't show any codes.
  3. #23 Re: Chugging?
    To check you could pull your front o2 sensor out and see if it runs better
  4. #24 Re: Chugging?
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    I found this thread so I thought I would ask about this too.. My car seem to pulsate on the RPM's around 2000rpm. It will go up and down by about 200-300 rpm's. This will happen on light acceerationas well. If I hit the gas it will go away. Mine seems to do it more when its cold.( I think) I also noticed it when I had all of my work done on the LIM gasket and UIM replacement. They put all new seals in including the throttle body gasket and the MAF sensor I think.. I have been wondering on what is causing this.
    I have all new O2 sensors so thats not ti
  5. #25 Re: Chugging?
    Nov 2009
    chicago
    Anyone? I haven't tried disconnecting the battery yet.. are those pars in the trans expensive to replace?
  6. #26 Re: Chugging?
    Clean the TB, do a tune up if it hasn't been done recently. Igniton is usually the most common item to cause this.
  7. #27 Re: Chugging?
    Nov 2010
    Sidney, OH
    Just brought the car into the shop today... Waiting to hear back to find out what it was..
    -ljmonnin12
  8. #28 Re: Chugging?
    Nov 2009
    chicago
    Any update
  9. #29 Re: Chugging?
    Nov 2010
    Sidney, OH
    Nope... Just waiting on them to tell me what's wrong...
    -ljmonnin12
  10. #30 Re: Chugging?
    Nov 2010
    Sidney, OH
    So I took my car to two different mechanics..... Neither one of them can find out what's wrong... They definitely can tell a loss of engine power but can't figure out what is causing it. I'm stuck...
    -ljmonnin12
  11. #31 Re: Chugging?
    Nov 2010
    Sidney, OH
    Update: Cleaned the tb... Still nothing... Still runs like shiot.
    dirty tb
    video of it.... it feels worse than it looks
    IMG_0124.mp4 video by ljmonnin12 - Photobucket
    -ljmonnin12
  12. #32 Re: Chugging?
    The video seems normal to me i didn't see anything abnormal.
  13. #33 Re: Chugging?
    Nov 2010
    Sidney, OH
    It just seems a little sluggish for wot... When I'm under light acceleration it's a lot worse.
    -ljmonnin12
  14. #34 Re: Chugging?
    Nov 2010
    Sidney, OH
    Also, could a bad fuel filter cause these symptoms?
    -ljmonnin12
  15. #35 Re: Chugging?
    Nov 2010
    Sidney, OH
    Ok, so I just pulled the TCC fuse and the car ran like 50x worse... So does that mean it's not the TCC?
    -ljmonnin12
    Nov 2010
    Sidney, OH
    And I just realized there is a large amount of heat coming from below my center console. I can feel it coming through my cup holders.
    -ljmonnin12
  17. #37 Re: Chugging?
    thats your exhaust pipes, you shiftier cable boot is likely torn up and letting heat in the car. the cat is pretty much in line with the middle of the console too.
  18. #38 Re: Chugging?
    Nov 2010
    Sidney, OH
    I've never felt it that hot before.... Like it was blazing... I took out that little cubby like thing near the front of the console and put my hand down there and i'm pretty sure i burnt my fingers.
    -ljmonnin12
  19. #39 Re: Chugging?
    look under the car after its been running for a while at night in the dark, if its glowing red its shot/clogged up.
  20. #40 Re: Chugging?
    Nov 2010
    Sidney, OH
    I looked... but where my car was parked I couldnt really see all that well but I stuck my hand just to feel how much heat it was giving off and it was very hot... Is there any way except a back pressure tester that you can tell if it is the cat?
    -ljmonnin12
  1. chugging
    By Scottydoggs in forum General Tech Discussion
    Last Post: 08-20-2012, 12:41 PM
  2. 02 GT hesitation/chugging
    By justinmc84 in forum General Tech Discussion
    Last Post: 07-28-2011, 11:17 AM
  3. Chugging
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2011, 08:02 PM
  4. chugging
    By davisg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2011, 06:01 AM
  5. Stuttering... Chugging?!?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 06:53 PM
