Thread: Need Help! Loss of Power
Results 1 to 9 of 9
  1. #1 Need Help! Loss of Power
    Jul 2012
    North Dakota
    A couple weeks ago my car (3.8 Litre V6 L36) would suck in air when i put some throttle down or when i went to speed up on interstate, i noticed i had a lower intake manifold gasket leaking and figured it was due to that, so i replaced the lower intake manifold gaskets, upper intake manifold gaskets, valve cover gaskets, and throttle body gasket, but the loss of power and air sucking noise still continued. I also noticed i had a plug wire that kept shorting and sparking on the engine bracket so i replaced plugs and wires last night. Took it driving today, still didnt solve the problem. Does anyone know what this could be? When i give it throttle it revs and has no power behind the rev, sounds like air is being sucked in
    Thanks
  2. #2 Re: Need Help! Loss of Power
    does it sound like a vacuum? just the sucking sound but not much out the tail pipe? if you have no check engine light on, id be thinking clogged cat.
    whats your miles on the engine? and year?
  3. #3 Re: Need Help! Loss of Power
    Jul 2012
    North Dakota
    2001 GPGT 3.8 Non supercharged with 109K on it, i dont think its vacuum, my car runs perfectly fine cold, then when it warms up it starts chugging and losing power on light acceleration
  4. #4 Re: Need Help! Loss of Power
    pull the upper 02 sensor off and see if it runs better with the huge exhaust leak.
    look under the car at night after driving it to see if the cat is glowing red. when the car is cold get it up and get under it, hit the cat hard with your palm, do you hear anything rattling around inside?
    all signs of a bad cat.
  5. #5 Re: Need Help! Loss of Power
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    I second Cat
  6. #6 Re: Need Help! Loss of Power
    Jul 2012
    North Dakota
    Did a back pressure test on the cat, at idle i had 3 psi of back pressure then with rpms the psi needle pegged all the way, getting a new cat today, hopefully this was the problem, thanks for your help
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I gutted my cat but it was doing the same thing. Mine wasn't glowing or smelling bad either...but it was making that sucking of air noise. All is great now... I removed the resonator at the same time
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  8. #8 Re: Need Help! Loss of Power
    Jul 2012
    North Dakota
    So put on new cat, totally got rid of the problem, have tons of power back to the engine, runs amazing
  9. #9 Re: Need Help! Loss of Power
    good to hear.
  1. Power Loss
    By Stinkygrub in forum Engine
    Last Post: 07-20-2021, 09:11 PM
  2. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  3. another loss of power :S
    By ChdMcD in forum General Tech Discussion
    Last Post: 07-31-2010, 07:08 PM
  4. power loss
    Last Post: 04-15-2010, 02:57 PM
  5. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
