Thread: Power Steering Pump On Its Way Out
Results 1 to 3 of 3
  1. #1 Power Steering Pump On Its Way Out
    SE Level Member Danarchy's Avatar
    Sep 2012
    Hello everyone, new guy here. I was just cruisin after restoring the plastic on the headlights last night and noticed the power steering pump whining even louder than usual, a lot more higher pitched whine. Its always been noisy but now its real bad.
    I checked the fluid and it looked fine (PIA to get at) and no leaks that I can see. What am I up against if I decide to change it? I assume I need to pull the dogbone bolts for starters and move the engine forward since I can barely get my hand down there...
    Thanks!
    Dan
    2005 Grand Prix GT - Stock - K&N Drop-In, Deer Whistlers on the Bumper
    2007 Chevrolet Silverado LT (NBS) Ext. Cab 5.3L V8
  2. #2 Re: Power Steering Pump On Its Way Out
    You want the easy way or the had way?
    Easy:
    Pull the alt and it's bracket. PS pump is much easier to get at. You'll replace your coolant elbows at the same time and some coolant. Likely you'll do most of the work through the wheel well, but you'll take the pump out the top.
    Hard:
    Do it all through the wheel well.
    Hey.. I know that's not much info, it's early and I'm on autopilot. I'd pull the alt personally.
  3. #3 Re: Power Steering Pump On Its Way Out
    Sep 2012
    Thanks Bill, it's a start!
  1. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  2. noisy power steering pump?
    By Teardrop in forum General Tech Discussion
    Last Post: 12-26-2010, 10:01 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
