Thread: Engine bogs down intermittently at idle - poor MPG
Results 1 to 20 of 20
  1. #1 Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    04 GT N/A 65K "no CEL"
    For several months now I've noticed the car bog down to 300 RPM then pop back up to normal - sort of a hesitation or hiccup - at idle only when I was coming off the freeway to a stop. Didn't happen often and only 1 or 2 "hiccups". Idle never went high, always bogged low.
    I changed the wires and plugs recently and added a HAI as shown in some posts on here with PVC and couplers from Home Depot. After these changes, the car ran better but problem still persisted.
    In the last week, the same problem is becoming more frequent and now it's happening at any time, not just coming off the highway. And sometimes the idle will go down a dozen times in a row. It hasn't died, no problems starting, and no power issues that I can tell. When I go WOT everything seems fine.
    Then only other thing I've noticed and I can't put my finger on the timing is that I'm getting pretty lousy gas mileage. 18MPG in the city with A/C running. I don't drive it hard. I drove it out of town a couple weekends ago and got about 26 on the HWY. 93 octane gas. Tires at 35psi. It does seem that I noticed the drop in MPG about the time I installed the HAI although that was also the time that I started paying closer attention to it - so not sure...
    I don't know if this is one problem or two but I wanted to provide all the info I have.
    I ordered an O2 sensor and fuel filter from rockauto and should have that installed when it arrives.
    What else should I be looking at?
    Thanks in advance.
  2. #2 Re: Engine bogs down intermittently at idle - poor MPG
    St. Louis
    Well, being N/A the 93 won't help you any, but your call there. Being an 04 I'd pull the entire throttle body off and clean it until it looks new, and then also clean the MAF with approved MAF cleaner (do NOT use brake or carb cleaner on the MAF). Reinstall and see what you get. I'd bet the TB is all gunked up.
  3. #3 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Thanks for the tip on the 93.
    I should have added more info - I cleaned the TB and MAF when I installed the HAI on July 4th weekend.
    Should also add the problem seems to be only after driving. I've never noticed it right after start up on either a hot or cold engine. It always seems to be coming to a stop after driving. I'm also not sure if I've ever noticed it in PARK at all...
  4. #4 Re: Engine bogs down intermittently at idle - poor MPG
    Steve..it's all good.. sorry I missed it.
    Start the car and tap on the maf sensor. If you had added the HAI after the issue started, I'd say maybe oil on the maf, but you did it after. If the tapping doesn't change the way it's idling etc, turn it off...unplug the maf and start it up. It may stumble for a minute or two trying to learn based on the pcm table vs actual airflow. Try driving it like that for a day. Don't go wide open or beat on it, just drive it nicely. If the issue no longer exisits..clean/replace the maf.
  5. #5 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Bill, thanks.
    With a screwdriver I tapped on and around the MAF and no change. When you mentioned oil though I remembered that I did oil the filter some time after I installed it - I wasn't sure if it needed it off the shelf - I tried to go very lightly on the oil. So:
    1) I checked the TB - still clean.
    2) I noticed some of the coupling bands were loose - not sure how I missed this yesterday - but I tightened everything back up.
    3) I cleaned the MAF again with MAF cleaner - I will drive today and see if that changes anything. Otherwise, I will unplug and test as you suggested.
    4) I've attached a picture - can you tell me if it is ok for the MAF to be closer to the filter as it is or should it be up closer to the TB? I wasn't sure about this when I installed.
    5) Should I oil this filter or not - I've read differing opinions. Spectre filter.
    I'll post back updates once I have them.
    [IMG][/IMG]
  6. #6 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Update:
    Drove city and hwy after cleaning MAF and tightening up coupler bands.
    Car fired noticeably quicker. Throttle response and acceleration noticeably better. RPMs didn't pop up and down, but it hasn't been doing it all the time so I'll keep an eye on it. I started out with the AC off. Drove about 3/4 of my drive with it off. Then at a stop light turned it on. When I turned on the AC the RPM fluttered for a bit then seemed to settle out before I came to the next stop. Didn't see much fluctuation after that though so maybe it was just adjusting to the cleaner MAF when load came on it. Although the AC seems to be straining it...I don't know, maybe I'm making it up in my head.
    Cleaning the MAF certainly made a difference. I had no idea filter oil would affect it that much and that fast. Is there a dry cone filter?
    So I filled up the tank and will see what happens. Keeping an eye on it bogging down.
    BTW - MPG for my last 4 tanks including this last one:
    6/29 - 18.6 city
    7/1 - 26.5 hwy (I think I oiled the filter right before this trip)
    7/15 - 17.5 city
    7/25 - 16.3 city
  7. #7 Re: Engine bogs down intermittently at idle - poor MPG
    St. Louis
    I'd bet you were getting unmetered air in after the MAF and it was messing it up. Cleaning the MAF probably straightened the rest of it out. I love cheap fixes, lol..
  8. #8 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    FordMan - you were right the MAF needed cleaning. Wondering if I shouldn't just go with a dry flow cone for the future.
    Followed Bill's instructions and disconnected MAF - car runs even better with it disconnected. Wondering if I shouldn't replace MAF?
  9. #9 Re: Engine bogs down intermittently at idle - poor MPG
    Try driving with it connected. See if it acts up. Those loose clamps and dirty maf may have been the issue.
  10. #10 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Reconnected MAF this morning and put about 30 miles of city driving on it. Although not as bad as before, RPM still dance a little when coming to a stop but I wouldn't say it is the same bogging down I was experiencing. Could this be computer sorting itself out after the disconnecting and reconnecting yesterday?
    Also, w/ MAF disconnected yesterday the car drove much better in the low end range - accelerating from stop to say 35 MPH. Today it seems to work harder in that range with the MAF reconnected compared to it disconnected.
  11. #11 Re: Engine bogs down intermittently at idle - poor MPG
    May 2008
    staten island,NY
    is the maf in the same location as it was when it had the stock intake?
    if you moved the maf closer or further away from the stock location that will mess up the tune and cause the issue you're having
  12. #12 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    QwikGT - I wondered about that - and no, I moved the MAF further away from TB towards filter. I can change this and move closer to stock and see what that does.
    Just got back from another hour of test driving and the RPM issue still exists same as before. More pronounced when AC on, car warm, in gear, coming to a stop. Struggles to find it's idle.
    I received my O2 sensor and fuel filter today but want to sort this out before I throw other changes in the mix. I'll keep you posted.
  13. #13 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    So instead of screwing around with trying to re-position the MAF - I just put the stock box back on this morning - and cleaned the MAF again for good measure - and took it for a drive. This resolved the struggling in low RPM I was describing - in other words, a lot more acceleration with a lot less accelerator. Seems like this would address my MPG and general sluggishness issue I described. Stands to reason as those two issues seemed to appear about the time I installed the HAI.
    But the RPM jumping/bogging down still persists. Same conditions: at idle, after deceleration, transmission engaged, under load of AC.
    I'm going to install the fuel filter first, test, then install O2 sensor, test. Just to isolate them so if one of them works, I'll know which one. (not sure if these will address issue but I have them so I'm going to use them). Anything I else I should try? Does anyone think I'm still looking at a bad MAF?
  14. #14 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Update:
    I received my new MAF two days ago and installed it. Have put about 50 miles on it. RPM surge issue still exists. Car feels and runs better in some ways for sure, but original issue persists.
    I'm aware the issue only exists under load of A/C compressor. Where else should I be looking?
  15. #15 Re: Engine bogs down intermittently at idle - poor MPG
    Quote Originally Posted by QwikGT View Post
    Curious as to how distance from TB/engine would be the key factor.
    AFAIK, the tubing before and after would be the primary influences on accuracy.
    Having the MAF right after the filter means it might not be seeing the most laminar airflow that it could be. However a similar issues applies to having a bend before the MAF as well.
    As for the stock intake being better than a HAI, I would agree. The stock setup is essentially a quite "CAI".
    Unsure on what specifically is causing your issues.
    I find if the fuel trims are out of wack, it will struggle to find an idle in similar situations as you've described. Its very likely these are off as you had the HAI installed, and the PCM adapted to that.
    Since you've reinstalled the stock air box, I would suggest disconnecting the battery in hopes of resetting the fuel trims. Some say you should connect the neg/pos battery cables as apparently this causes a reset of the trims/trans adapt settings.
  16. #16 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    I'll try this. Thanks.
    Any chance this could be a vacuum leak?
  17. #17 Re: Engine bogs down intermittently at idle - poor MPG
    Yup.
  18. #18 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Yup.
    Sorry I'm a little new to some of this - any tips on a vacuum diagram - the only one that is obvious to me is the brake booster. I've searched on the forums and can't exactly find one. Is there a tree I should follow from?
  19. #19 Re: Engine bogs down intermittently at idle - poor MPG
    should be on your hood, on the emissions sticker.
  20. #20 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    Problem resolved - at least it seems. While looking for a vacuum leak, I noticed a nut missing on the crossover manifold right before the O2 sensor. After replacing, all seems good.
    [IMG][/IMG]
    Thanks for everyone's help. This forum has been a lifesaver ($$ saver) more than once.
  1. Engine bogs down/stalls when pumping brakes
    By Paranoid in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 02:52 PM
  2. HELP flashing check engine light/ poor acceleration
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2012, 02:55 PM
  3. Replies: 9
    Last Post: 01-06-2012, 11:37 AM
  4. Car bogs at 60+ when on the gas
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 01:34 AM
  5. Car Bogs down...
    By Maloro619 in forum General Tech Discussion
    Last Post: 03-22-2010, 08:26 PM
