Since you've reinstalled the stock air box, I would suggest disconnecting the battery in hopes of resetting the fuel trims. Some say you should connect the neg/pos battery cables as apparently this causes a reset of the trims/trans adapt settings.
I'll try this. Thanks.
Any chance this could be a vacuum leak?
