Thread: Engine bogs down intermittently at idle - poor MPG
Results 1 to 20 of 20
  1. #1 Re: Engine bogs down intermittently at idle - poor MPG
    Quote Originally Posted by QwikGT View Post
    is the maf in the same location as it was when it had the stock intake?
    if you moved the maf closer or further away from the stock location that will mess up the tune and cause the issue you're having
    Curious as to how distance from TB/engine would be the key factor.
    AFAIK, the tubing before and after would be the primary influences on accuracy.
    Having the MAF right after the filter means it might not be seeing the most laminar airflow that it could be. However a similar issues applies to having a bend before the MAF as well.
    As for the stock intake being better than a HAI, I would agree. The stock setup is essentially a quite "CAI".
    Unsure on what specifically is causing your issues.
    I find if the fuel trims are out of wack, it will struggle to find an idle in similar situations as you've described. Its very likely these are off as you had the HAI installed, and the PCM adapted to that.
    Since you've reinstalled the stock air box, I would suggest disconnecting the battery in hopes of resetting the fuel trims. Some say you should connect the neg/pos battery cables as apparently this causes a reset of the trims/trans adapt settings.
  2. #2 Re: Engine bogs down intermittently at idle - poor MPG
    Donating Users
    Texas
    I'll try this. Thanks.
    Any chance this could be a vacuum leak?
  1. Engine bogs down/stalls when pumping brakes
    By Paranoid in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 02:52 PM
  2. HELP flashing check engine light/ poor acceleration
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2012, 02:55 PM
  3. Replies: 9
    Last Post: 01-06-2012, 11:37 AM
  4. Car bogs at 60+ when on the gas
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 01:34 AM
  5. Car Bogs down...
    By Maloro619 in forum General Tech Discussion
    Last Post: 03-22-2010, 08:26 PM
