Thread: Transmission Fluid - 173K..To change or not to change, that is the question
Results 1 to 16 of 16
  1. #1 Re: Transmission Fluid - 173K..To change or not to change, that is the question
    Nov 2011
    Pike, NY
    As a practice over the years, when my tranny pan doesn't have it, I've been adding a drain plug. I got spoiled with the 4L80E's and some older truck trans that had them so I just bought them and put one in. Before I started adding the plugs, I normally changed the filter and fluids every 75k or so. Now I run the filter for 100k and make the fluid change around 50k........besides the plug makes draining a lot cleaner and easier.......wish they did them at the factory.
  2. #2 Re: Transmission Fluid - 173K..To change or not to change, that is the question
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    Quote Originally Posted by bloaty57 View Post
    how do you add that? welding? sounds nifty...
  1. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  2. Question about shifting and fluid change
    By tkennedy88 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2011, 12:23 PM
  3. looking to change tranny fluid
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2011, 05:48 PM
  4. Dex VI Fluid Change
    By The Guz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2010, 04:55 PM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
