Thread: Dex VI Fluid Change
Results 1 to 20 of 26
  1. #1 Dex VI Fluid Change
    Dec 2008
    Lawndale, CA
    I have a question for all you transmission experts. I am planning to change out the filter and fluid on my 99 GT and my brothers 03 GT. I have done it before on my 99 and I figured I would do both at the same time as regular maintenance. I searched on here and on other sites researching the swap to dexron VI. I have read good things and bad things about switching over to dex VI. I was wondering if any of you guys who have switched over have had any issues?
    Specs on both cars.
    99 GT with ~86K miles
    03 GT with ~65K miles
    Thanks,
    Mike
  2. #2 Re: Dex VI Fluid Change
    St. Louis
    I do not claim to be an expert on these trans. but I switched to Dex VI when I put a used trans. in my 00 GT. This was out of a 99 GP GT w/ approx. 100K on it. Since the original Dex III fluid was still nice and red, I went ahead and completely drained the TC while I had it out and then dropped the pan as well. Since I installed all new lines and a new rad., I would think I got 99.9% of the old fluid out.
    Since the install, I've put about 5K on it and it hasn't had an issue yet and the fluid still looks good. Shifts about as good as these slush-boxes get I guess. No idea on trans. temps though. No gauge for that.
    Jay
  3. #3 Re: Dex VI Fluid Change
    Donating Users
    South Deerfield, MA
    Changed to Dex VI a few months ago and no problems.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: Dex VI Fluid Change
    St. Cloud, MN
    I switched to Dex VI about two months ago and its been running just fine so far...
  5. #5 Re: Dex VI Fluid Change
    Dec 2008
    Lawndale, CA
    Thanks. I will end up going with dex VI for both vehicles.
  6. #6 Re: Dex VI Fluid Change
    Brewcity, WI
    I switched from III to VI at 123K (granted only 5K ago) with only doing a pan drop and still drives fine. So theoretically I have Dex 4.5....
    Self-denied SMGPFC member #1
    SEARCH works!
  7. #7 Re: Dex VI Fluid Change
    Aug 2008
    KCMO
    where the best place/price to get an OEM filter for a pan drop?
  8. #8 Re: Dex VI Fluid Change
    Im pretty sure any auto store should sell them.
    i think they are like 10-20 bucks.
  9. #9 Re: Dex VI Fluid Change
    Nov 2009
    Grand haven
    Dave from TEP said to me not to use the dex VI. But it is your car.
  10. #10 Re: Dex VI Fluid Change
    Aug 2008
    KCMO
    ^ if its not good then why did they put it in all the newer cars?
  11. #11 Re: Dex VI Fluid Change
    Nov 2009
    Grand haven
    I never said it was BAD^^. Dave just told me not to use dex VI. Give him a call tommrow and ask him why. I would have to say the newer cars have different clutch material? IDK
  12. #12 Re: Dex VI Fluid Change
    Aug 2008
    KCMO
    true
  13. #13 Re: Dex VI Fluid Change
    Largo, Florida, United States
    i switched when i swapped engines
    Temp fine
  14. #14 Re: Dex VI Fluid Change
    Quote Originally Posted by shawngtp View Post
    MOAR INFO!@#$%)(!*@#@!#
    should we just use "synthetic" dexron III then?
  15. #15 Re: Dex VI Fluid Change
    Charles City, IA
    From what I have read dex VI actually lets the trans slip a little more, but also keeps temps down some how.
    SMGPFC Two Nipple General
  16. #16 Re: Dex VI Fluid Change
    Grand Rapids, MI
    ha! so which is it then, III or VI??
    and when doing a pan drop a new pan gasket is mandatory, yes?
  17. #17 Re: Dex VI Fluid Change
    Charles City, IA
    you dont need a new gasket if you have the original one that is rubber. I would go with a synthetic dex III or multi vehicle fluid.
  18. #18 Re: Dex VI Fluid Change
    Dec 2008
    Lawndale, CA
    I contacted Dave to see what he says. Hopefully he chimes in here as well if he gets a chance.
  19. #19 Re: Dex VI Fluid Change
    Dec 2008
    Lawndale, CA
    Dave got back to me and I will be sticking with his recomendation of using dex 3 just to be safe. Thanks to all for the information provided.
  20. #20 Re: Dex VI Fluid Change
    St. Cloud, MN
    Why did he recommend staying with Dex 3? Just curious...
  1. Hardshifting after new fluid and filter change.
    By Pontiacman76 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:47 PM
  2. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
  3. Supercharger fluid change 01 gtp
    By brownb66 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:41 AM
  4. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
