Thread: Still getting hesitant acceleration
Results 1 to 16 of 16
  1. #1 Still getting hesitant acceleration
    Feb 2009
    South West Lower Michigan
    Ok folks here it goes. 1997 Pontiac Grand Prix, GT N/A 160,000....About three months ago, I started getting a misfire intermediately on my number one cylinder and started getting hesitant acceleration. Here is what I have replaced so far. New aftermarket Cat. New AC/Delco 41-401 Iridium spark plugs with AC/Delco wires. Cleaned all my sensors with the appropriate cleaner, checked my fuel pressure and was within specs. Had my coil packs tested and well within range. Cleaned my throttle body, "was clean to begin with". Unplugged my MAF and problem persists. Replaced PCV valve and air filter. I don't know where to turn next besides have my local dealership take a look at it. Yesterday I sea foamed my air intake and that seemed to straighten it out for a while but today the hesitant acceleration persists. Idle is strong and when I get to cruising speed it runs like brand new. The only thing else I can think of is maybe a stuck TCC? RPM's are where they're supposed to be with no problem with overdrive. I did take it to a local trans shop and they mentioned the TCC was sticking but according to my Tach, it has not been happening lately... Any ideas? Much appreciated!
    1997 Pontiac Grand Prix GT 3.8 N/A 160,000 Miles Dark Teal Metallic.
  2. #2 Re: Still getting hesitant acceleration
    Apr 2009
    Fort Worth TX
    Make sure fuel pressure is within spec when PCM is commanding higher injector duty cycle during acceleration.
    If that's good then move injector for #1 cylinder to another cylinder and see if misfire follows.
  3. #3 Re: Still getting hesitant acceleration
    I'm going to go look for your other threads and probably merge them.
  4. #4 Re: Still getting hesitant acceleration
    Ehhh couldn't find it. Is the issue still a #1 misfire?
  5. #5 Re: Still getting hesitant acceleration
    Feb 2009
    Not getting an engine light after the plug and wires were replaced. Fuel injectors make sense but how to test these without a misfire check engine light?
  6. #6 Re: Still getting hesitant acceleration
    Please..don't think in terms of engine light. That isn't going to fix this issue. You need a scanner to watch the data and see if you have a misfire.
  7. #7 Re: Still getting hesitant acceleration
    Feb 2009
    Ok, I do have an OBD II scanner but pretty sure I can't watch the data. Sorry If have started two posts on the same issue...I can't recall posting here with this problem...Old Age.....
  8. #8 Re: Still getting hesitant acceleration
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    i thought the obII's read the data? or maybe you need an attatchment or something.. did u try switching #1 injector to any where else? or maybe check the ohms on it it with a multimeter, or both lol
  9. #9 Re: Still getting hesitant acceleration
    May 2012
    pensalvania
    my bad, you actually need one like this: Buy Actron AutoScanner Plus OBD II Scan Tool CP9580 at Advance Auto Parts other ones only read the cel's
  10. #10 Re: Still getting hesitant acceleration
    Feb 2009
    Ok I did throw a code this afternoon. PO121 TPS code....This certainly makes sense....Will Swap out and let everyone know how it goes!
  11. #11 Re: Still getting hesitant acceleration
    Apr 2009
    Fort Worth TX
    Interesting.
  12. #12 Re: Still getting hesitant acceleration
    Feb 2009
    To say the least....I replaced this TPS about five years ago from Autozone...Ya think? I ordered an OEM Replacement
  13. #13 Re: Still getting hesitant acceleration
    May 2012
    pensalvania
    i use auto zone parts, and never had a problem..yet lol
  14. #14 Re: Still getting hesitant acceleration
    Feb 2009
    We'll see if this takes care of it. Like BillBoost37 commented, it may need further investigation....
  15. #15 Re: Still getting hesitant acceleration
    I'll take a check engine light when I can, have found with misfires that they are best found scanning while driving. I wasn't expecting a tps. Was thinking more along the lines of ignition system, which is common to our platform.
  16. #16 Re: Still getting hesitant acceleration
    Feb 2009
    Installed new sensor Friday and has solved my acceleration problem. Thanks everybody for their input! Grand Prix owners are the best!
  1. Jerky hesitant acceleration @WOT
    By Zbones in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2012, 09:11 PM
  2. Hesitant on acceleration
    By Junixx in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-14-2010, 09:15 AM
  3. Car being hesitant
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 09:32 PM
  4. 04 GP GT hesitant shift......
    By skubasteve! in forum General Tech Discussion
    Last Post: 04-07-2009, 02:13 PM
  5. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
