Thread: Cam or rockers? Topswap or HV3?
Results 1 to 20 of 37
  1. #1 Cam or rockers? Topswap or HV3?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Yes I have used the search bar already. Couldn't find any solid info.
    For a NA GP, would camming or rockers be better for performance? Why?
    Also for NA, is it better to do a topswap, or an HV3 insert?
    Now if I topswapped, would a cam or rockers be better?
  2. #2 Re: Cam or rockers? Topswap or HV3?
    Jan 2009
    Tallahassee, FL
    Depends on what your goals are? Do you want to make a little more power and it be pretty easy? Or do you want power? How much are you willing to spend?
    The topswap and cam will give you the most power, an HV3 and rockers will give you a good bump and be simple to do.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Cam or rockers? Topswap or HV3?
    Minnesota
    Answers:
    Cam
    Topswap
    Cam
    If you are talking power to power relation then a cam and top swap will beat N/A mods any day.
  4. #4 Re: Cam or rockers? Topswap or HV3?
    Grand Island, Nebraska
    A cammed topswap should be basement 13's with a pulley if you want to bench race. An L36 with HV3 and rockers might be low 15s. maybe.
    Mar 2012
    Minneapolis MN
    I think I want more power. My limit is 2 grand
  6. #6 Re: Cam or rockers? Topswap or HV3?
    Omaha, NE
    Quote Originally Posted by Kolton Lock View Post
    DD The GP and get a real car with more power... This is a plan you won't regret.
    If you MUST mod the GP, for 2k you can put on a good turbo.
  7. #7 Re: Cam or rockers? Topswap or HV3?
    new britain, ct
    you only have 2k...dont go turbo, chances are you will need a trans and you WILL need a tuner and youll end up paying more than 2k for a turbo setup.
    for 2k....i would do a top swap, get a cam/headers. drop a pulley size to maybe a 3.6/3.5. scan for kr and tune.
    07 Black GXP.
  8. #8 Re: Cam or rockers? Topswap or HV3?
    Omaha, NE
    Even on a topswap, you should get a tune. You can turn down turbo boost with a boost controller easier than swapping pullies.
    All it takes is common sense and not driving like a dbag and a trans will hold up just fine.
  9. #9 Re: Cam or rockers? Topswap or HV3?
    NEED a tune for a top swap.
    Unless you plan on reusing your L36 injectors and TB.
    Which should never happen.
  10. #10 Re: Cam or rockers? Topswap or HV3?
    Omaha, NE
    NEED is a strong word. As long as you're on a 3.8 pulley and don't abuse the car a GTP tune should be sufficient.
    That is one of those things that will never be confirmed though.
  11. #11 Re: Cam or rockers? Topswap or HV3?
    Still won't.
    GTP PCM will have GTP trans settings which will not work with a GT transmission.
  12. #12 Re: Cam or rockers? Topswap or HV3?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    why would you topswap just to not abuse the car? why most people add power lols.
    To the op, do you want any mpg's? cam,rockers will take that away alot more then the other mods you asked about..
    topswap will also if your in the pedal alot.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  13. #13 Re: Cam or rockers? Topswap or HV3?
    NOS...no seriously.
  14. #14 Re: Cam or rockers? Topswap or HV3?
    Omaha, NE
    Quote Originally Posted by JoRoW99 View Post
    NOS...no seriously.
    You mean Nitrous??????????????????????????????????????????
  15. #15 Re: Cam or rockers? Topswap or HV3?
    Omaha, NE
    Ahh, you got me there. I wonder what would happen if someone tried it anyway.
  16. #16 Re: Cam or rockers? Topswap or HV3?
    I ran my GT PCM with my L36 injectors for a while...but that was without boost and just so i could get around cuz WBS took like 3+ weeks to get me everything. Dont ever do it. I was also scanning at the time.
  17. #17 Re: Cam or rockers? Topswap or HV3?
    Minnesota
    The car will shift like crap and throw codes of you have the incorrect gear ratio in the PCM. Plus you will want to change the shift points for 3.29s.
  18. #18 Re: Cam or rockers? Topswap or HV3?
    Florida
    On the contrary, rockers actually add mpg.I gained an additional 10-15miles to the tank after the ER's. I hear a cam may take away city mpgs but help highway mpgs.
  19. #19 Re: Cam or rockers? Topswap or HV3?
    St Thomas Ontario
    how does adding fuel increase mpgs?
    be nice im not "mechanically inclined" lol
    Ohio
    Cam and rockers are FLOW mods.... More flow equals less wasted energy. Less wasted energy equals better gas mileage.
  1. Topswap for $500?
    By mattstansbury in forum General Tech Discussion
    Last Post: 09-11-2011, 10:50 AM
  2. L67, L32, or L26 Topswap
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:46 PM
