Thread: Which Oil Pressure Switch?
Results 1 to 4 of 4
  1. #1 Which Oil Pressure Switch?
    Feb 2009
    South West Lower Michigan
    Trying to figure out which oil pressure switch I need for my 97 N/A four door 3.8
    Rock Auto has two AC/Delco's with different prices below. Would both of these work and if not, which one would I need? Thanks for any info.
    ACDELCO Part # D1835A {#12575008}
    SWITCH,ENG OIL PRESS IND
    $13.24
    ACDELCO Part # D8048 {#89057517}
    SWITCH,ENG OIL PRESS IND 4 DOORS
    SWITCH,ENG OIL PRESS IND 2 DOORS
    $22.99
  2. #2 Re: Which Oil Pressure Switch?
    id just go to napa and pick one up.
    Should be around the same cost for a ac delco one.
  3. #3 Re: Which Oil Pressure Switch?
    Apr 2009
    Fort Worth TX
    It looks like they are the same switch with slightly different connectors. The very typical one is the D1835A. The D8048 may have been used partially in 97. Pull the connector off of yours and see which connector it is.
  4. #4 Re: Which Oil Pressure Switch?
    Feb 2009
    I have store credit so I wanted to use it up....I did in fact order the D1835A. Thanks for your replies.
  1. stupid oil pressure switch
    By twol8uluz in forum General Tech Discussion
    Last Post: 09-06-2011, 03:25 PM
  2. Where is A/C pressure switch?
    By PCweber in forum General Tech Discussion
    Last Post: 03-29-2009, 07:13 PM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
