Thread: o-ring replacement
Results 1 to 6 of 6
  1. #1 o-ring replacement
    SE Level Member erice's Avatar
    Oct 2011
    tampa
    i just replaced my upper intake but i'm having a problem getting the new o-ring on the fuel injectors. I put a little bit of oil on the rings, small one goes on fine but the thicker one i'm having problems with. Is there a trick I'm missing.
  2. #2 Re: o-ring replacement
    What car are you working on?
    O-rings are the same size top and bottom on 97-03 and I believe 04+ is the same.
  3. #3 Re: o-ring replacement
    Oct 2011
    tampa
    99 grand prix 3800. The ones I have a came with a kit but the ones already installed has a two rings, close to same size but the thickness is different.
  4. #4 Re: o-ring replacement
    Oct 2011
    tampa
    the new rings are the same size as the old, but just trying to roll them thicker one can't get over the little lip about 1/4 inch up from the tip of the injector. I'm only using my fingers.
  5. #5 Re: o-ring replacement
    Nov 2011
    NY
    I used these to help...
    4 Piece Pick and Hook Set
    But be careful, I did break one of the injector's plastic ring that holds the rubber O-Ring in place. No biggie, just letting you know.
  6. #6 Re: o-ring replacement
    Oct 2011
    tampa
    thanks
    i just got it to work.
  1. So you go to teh 'Ring
    By Odi in forum Off Topic Discussion
    Last Post: 04-16-2012, 11:33 PM
  2. PCV O-ring
    By zeppelin913 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 11:05 PM
  3. CV axle: snap ring and abs ring
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 09-13-2010, 03:47 PM
  4. Fuel Pump o-ring replacement
    By Sowhatsup2000 in forum General Tech Discussion
    Last Post: 04-07-2010, 04:16 PM
  5. PCV Valve O-Ring?
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:25 AM
