Thread: Intake Replaced, Still Running Lean
Results 1 to 20 of 20
  1. #1 Intake Replaced, Still Running Lean
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    I just got done replacing my UIM and its still running lean. When I take the oil cap off the idle changes and you can hear alot of air being sucked in.
    98 Pontiac Grand Prix Running Lean - YouTube
    _________________________
    1998 Pontiac Grand Prix GT 3.8
    Lowered 3 Inches
    Cat, EGR, U-Bend Delete, 3" Exhaust All The Way Back Into Duals
    Aluminium Sub-Frame
    Power Steering, Trans Cooler, Soon Oil Cooler
    K&N Custom Made Cold Air
    Denso IT16 Plugs, MSD Coils, MSD Wires
    12k HID
    LEDS
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #2 Re: Intake Replaced, Still Running Lean
    Banned
    Sioux Falls, SD
    Vaccum leak?
  3. #3 Re: Intake Replaced, Still Running Lean
    blocked pcv.
  4. #4 Re: Intake Replaced, Still Running Lean
    what leads you to believe youre running lean?
    i also agree with matt. replace your PCV.
  5. #5 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    I replaced the pcv, runs little better, doesnt pull air from the crank. the SES P0171
  6. #6 Re: Intake Replaced, Still Running Lean
    St. Louis
    IIRC that code states that bank 1 is lean. May indicate an O2 sensor issue.
    When you replaced the PCV did you make sure it had 2 orings on it, one on the PCV itself and the larger one that rests in the UIM? I think there should also be a sping on top of it as well. You may still have a slight vac. leak throwing the lean code.
  7. #7 Re: Intake Replaced, Still Running Lean
    I have never seen an O2 be a lean bank issue. Please read this link
    GearChatter.com :: View topic - DTC P0171 or P0174
    That should give us a good understanding of how/why the code sets.
    From my experience I have found this code to typically be:
    The metal tube under the throttle body from the EGR to the LIM. These crack at the lim where the piece holds it.
    Vacuum lines cracked/broken: specifially on the NA at the throttle body. Look at those silly goofy connections and ask yourself..how can they not split and leak.
    UIM to LIM gasket. It's not all that common. But when the bolts go in with 89in lbs of torque (hand tight if that) and you are worried about breaking the plastic manifold (97-03), it's understandable.
    TB to UIM gasket: It happens..and it's pretty common.
    PCV: Missing an o-ring top (cap) or bottom (under/on pcv) is quite common and would cause this.
    Battery cables: Yes..the cables being corroded not only at the battery but inside the cable itself can screw with voltage etc just enough to throw P0171 and send you on a 3-4 month journey that lands you swapping on new cables because you have no hair left. Pull the cables off the battery, remove the bolt and then pull the plastic boot off. Take a good look. Any corrosion is bad.
    FalconJohn has a thread going and I took a look at his car. The only thing I could remotely find were a bad vacuum line at the TB and his battery cables were questionable. He's still fighting the code, replaced the positive cable..and I'm awaiting him to replace the negative cable... FWIW I shotgunned a good used O2 on the car and there was no change.
  8. #8 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    Quote Originally Posted by FordMan77 View Post
    The pcv didn't, I'll throw one on and clear the code
    I've changed the o2 couple months back
    I swapped out the plastic vac lines with rubber back when I did the o2
    I know my batt cables do need to be replaced
    I'll try these tips and report back
  9. #9 Re: Intake Replaced, Still Running Lean
    Tucson, AZ
    Does your HVAC routing system work? In other words, if you select "defrost," does the air route to the windshield area, and does it blow out the driver and passenger vents if you select them? I ask because I had the same code once, and it turns out the vacuum line that supplied vacuum to the HVAC control was disconnected; It's the line that runs along the firewall, to the passenger fender well. If disconnected and leaking, the HVAC controls will not function properly and you will get a bank 1 lean code.
  10. #10 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    Yea they work. i put the o-ring on the pcv value, cleared the code and drove it about 10 miles today and its back. When I stop and go to hit the gas it almost dies but catches and takes off, and some times when it driving around 35mph and chokes
  11. #11 Re: Intake Replaced, Still Running Lean
    Tucson, AZ
    Sorry to hear that. Have you tried spraying starter fluid near where vacuum leaks may be present, listening for a change in idle?
  12. #12 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    I just did that, i did find a little leak by the brake vac line. the o ring didnt seat right. it just seems loose. I just did the big 3 with 0\1 gauge wireing. So i'm keeping my fingers crossed
  13. #13 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    So far so good Thanks Guys\Girls
  14. #14 Re: Intake Replaced, Still Running Lean
    SE Level Member Fritcr's Avatar
    Apr 2008
    Sorry to hijack but what fixed it? The new wiring or the brake boster thing?
  15. #15 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    The new UIM, the brake booster hose didn't go back in right and the o ring popped out of it groove when i went to put it back.
  16. #16 Re: Intake Replaced, Still Running Lean
    Apr 2008
    Thanks...looks like I will putting a new UIM on!
  17. #17 Re: Intake Replaced, Still Running Lean
    Jun 2011
    Watertown, SD
    Let me know how it goes
  18. #18 Re: Intake Replaced, Still Running Lean
    Be sure and double check that EGR tube while you are there.
  19. #19 Re: Intake Replaced, Still Running Lean
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Sorry i don't mean to butt in, except i recently had the same problem i replaced the LIM gasket and the UIM gaskets got it all back together started it and instantly could hear a vacuum leak i ignored it and eventually the SES light came on i took it to a shop a buddy of mine works at and they put it on a scanner and it indicated a lean condition. So I went home took it all back apart to find out what was causing it. Turns out the LIM had a small piece of old UIM gasket still stuck on it that i had missed that was preventing it from sealing and allowing air to leak in. Moral of the story make sure everything is VERY, VERY clean before you put it all back together. Hope this helps.
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  20. #20 Re: Intake Replaced, Still Running Lean
    Akron Ohio
    Did you check the first O2 sensor???
  1. Im running too lean?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-13-2011, 12:36 PM
  2. Running lean
    By camarofan1974 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 03:25 PM
  3. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  4. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
  5. STILL running lean..why!?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-22-2009, 12:26 AM
