I looked at changing the oil pan gasket on this 2004 GP. The 15 mm bolt at the top/rear part of the front engine mount is difficult to remove (as mentioned elsewhere in this forum). I can loosen the bolt easy enough but I can't find a way to get my hand in there to either get that bolt out ot hold it in place as I remove the bracket.
So, the question is - does that bolt have to come out to remove the bracket (In order to drop the pan)? Or, is it sufficient to only loosen that bolt, swing the bracket away from the pan some and maneuver the pan out?
Thanks!
