Disconnect both front dogbone mounts and put a ratchet strap somewhere on the back of the motor (at factory there is a hook somewhere near the alt) and connect the other end to the rad. support. Then just pull the motor forward thus rocking the backside away from the firewall. Keep in mind your downpipe is still attached and you may hit the tunnel if you pull it too far.
