Thread: Where is the thermostat located on a 01 GT??
Results 1 to 13 of 13
  1. #1 Where is the thermostat located on a 01 GT??
    SE Level Member nickdemio's Avatar
    STL
    I got a o1 Grand Prix GT(2dr) and need to change the thermostat, but dont know were its located. Could somebody please help me with the location & how i go about fixing it. Thanks!
    2001 GP GT
  2. #2 Re: Where is the thermostat located on a 01 GT??
    Brewcity, WI
    Quote Originally Posted by nickdemio View Post
    http://www.grandprixforums.net/therm...ent-37603.html
    search works on this site fyi...
    Self-denied SMGPFC member #1
    SEARCH works!
  3. #3 Re: Where is the thermostat located on a 01 GT??
    follow the upper rad hose to the LIM (block), and there are 2 bolts on housing that holds the thermostat
  4. #4 Re: Where is the thermostat located on a 01 GT??
    STL
    Thanks bro! It just started acting up today. Like if i sit at a light..it starts to run hot and then once im driving..it starts to cool down. Im hoping it just needs the thermostat replaced, cause i dont see any leaks.
    2001 GP GT
  5. #5 Re: Where is the thermostat located on a 01 GT??
    Grand Rapids, MI
    Well...are you leaking any coolant? How many miles also??
    But it could just mean you need to bleed the coolant if you've been fooling around with it. Sometimes people don't know to bleed it and it can cause temp. to fluctuate some.
  6. #6 Re: Where is the thermostat located on a 01 GT??
    STL
    Quote Originally Posted by brandonl2000 View Post
    Its not leaking coolant as said above & i havent touched anything yet. Just came back from o'reilys and told him bout my problem and he said it sounds like the thermostat. Car has 170, xxxx on it. Im just thinking it needs to be replaced, cause of the miles..i had the car for a year
    2001 GP GT
  7. #7 Re: Where is the thermostat located on a 01 GT??
    not a problem
    after you replace it, just make sure you bleed the system of air to insure that it dont overheat on you.
    There is a bleeder screw on top of the housing that you open 1-2 turns and with the car running you let it heat up and wait for coolant to start streaming out of the bleeder. Wait till its a steady stream, because you want to make sure all the air gets out, it may take 5-10 mins but its no big deal. Then just close it up and take it for a drive to see if it helps.
  8. #8 Re: Where is the thermostat located on a 01 GT??
    STL
    not a problem
    No doubt...will do! Thanks
    2001 GP GT
  9. #9 Re: Where is the thermostat located on a 01 GT??
    Grand Rapids, MI
    if itsn't the thermostat, pump or fans or something like that...might want to look into your LIM gaskets. i know Austin had lots of overheating problems and it turned out his LIM gaskets were the culprit. but regardless you should already have these gaskets replace as maintenance.
  10. #10 Re: Where is the thermostat located on a 01 GT??
    STL
    cool!
    2001 GP GT
  11. #11 Re: Where is the thermostat located on a 01 GT??
    I wouldn't think it's a thermostat or LIM gaskets.
    If the car cools when under power (more heat generated in engine) and has airflow through the radiator, yet heats up when sitting still. That would usually be an airflow problem. Depending on how much it's heating up (fans come on at ~216F and ~228F on most stock tunes).
    I'd be checking the fans and fuses to them, as well as confirming the pcm is seeing the same temps as the dash.
  12. #12 Re: Where is the thermostat located on a 01 GT??
    Apr 2011
    Tally, FL
    So what happening if the dashboard is showing lower temps than the pcm is reading?
  13. #13 Re: Where is the thermostat located on a 01 GT??
    If the dash shows less than pcm, the fans should be coming on at ~216F and ~228F pcm temp reading.
    If the dash shows more than the pcm, the fans should be coming on at ~216F and ~228F pcm temp reading
    If the dash and pcm don't match, either the dash gauge is bad or the temp sender is bad. Our temp senders have two senders built into them. One for the dash, one for the pcm.
  1. Need help knowing where cylinder 6 is located
    By Jbruce in forum General Tech Discussion
    Last Post: 08-17-2011, 03:59 PM
  2. Does anybody know where the IAC sensor or TB screen is located??
    By nickdemio in forum General Tech Discussion
    Last Post: 03-27-2011, 04:10 PM
  3. Where is the coolant temp sensor located?
    By usetaboost in forum General Tech Discussion
    Last Post: 11-26-2010, 06:34 PM
  4. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
