Thread: engine install?
Results 1 to 9 of 9
  1. #1 engine install?
    Kansas City, MO
    Is there any tricks to getting the engine to line back up with the transmission after it was been out of the vehicle I have been struggling with it for about a hour now
  2. #2 Re: engine install?
    Grand Rapids, MI
    i found that jacking the trans up ever so slightly helped a lot. and i actually removed the oil filter housing which bought me a few inches of play room. i won't do it again because i had to stand on my head to get it bolted back up. but you do what you gotta do.
    may have to angle the chains a certain way with the tranny jacked up and get it to slide together.
  3. #3 Re: engine install?
    Charles City, IA
    Yeah just jack up the passenger side of the trans a bit and go at an angle. They slide right in.
    SMGPFC Two Nipple General
  4. #4 Re: engine install?
    Florida
    Mallet....seriously, helped me a ton. Also, as soon as you have 1 guide-pin in, and can start the top 2 bolts, do so, but just get a few threads in. it'll keep it from popping back out during the process of fine wiggling on the engine (yanking and cussing at it to go in)
    And I've only jacked the tranny up a little bit once, and it didn't help too much IMO, but its worth trying.
  5. #5 Re: engine install?
    Kansas City, MO
    Thanks Guys! I got it. I did remove the oil filter adapter though so this should be fun to reattach
  6. #6 Re: engine install?
    Grand Rapids, MI
    yeah. i just had to stand on my head and reach my skinny arms down there and slowly bolt it up.
  7. #7 Re: engine install?
    Florida
    OH god.....I did that once..and wanted to shoot myself. Make sure you grab a new gasket, and some gasket remover..cause of how crazy the mating surface is, its a pain to get it all off.
    2 of the bolts arent bad to get to...but the 2 bottom ones are...took me prolly 45 minutes with a wobble-joint to get them tight.
    Glad it's in tho, thats a major step in the right direction.
  8. #8 Re: engine install?
    Antioch, IL
    that oil filter adpater is a PITFA to put back on. I used a ratchet and wrench and kept dropping them both. pos
    2009 Challenger SRT8
    Expert at being gay.
  9. #9 Re: engine install?
    St. Louis
    Yet another reason why my motors always come out w/ the trans on them. Sure you can leave it in, but its not much more to take loose to bring the trans with it. Then I don't have to fight with it
  1. Engine install cost
    By rotti3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2011, 10:30 AM
  2. So, putting engine back together after cam install
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 08:25 AM
  3. Can I install eaton m62 supercharger on L36 engine?
    By SBB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 01:15 PM
  4. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  5. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
