NegativeOne13
Sounds like an issue I was having with my '05. I had pretty much the same symptoms and replaced the APPS hoping it wasn't the TCC. Ended up being the TCC and the tranny was replaced under warranty. The best thing to do is hook up a scan tool that shows real time data (i.e. Snap-On Solus), and take it for a drive. When the RPM fluctuates watch to see if the TCC is locking up or not. Also try enabling the lock up via scan tool to see if the fluctuation goes away. Not all tools will allow you to lock up, but hopefully you know a friend that has one that you can borrow.
